Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
6.0 cam hp too low??
Old Dec 30, 2008 | 08:08 PM
Default 6.0 cam hp too low??
Ok we so took my friends truck to do a dyno tune on the new setup, here are the mods
2004 silverado ecsb 4x4
6.0 lq4 engine
232/234 .598 112 cam
pacesetter LT's with ORY pipe
Performabuilt level 3 tranny
3800 billet stall
The best we got out of it tuned was 311 rwhp and 329 torque in third gear with converter locked. Do these numbers look a little too low for the mods it has?
Old Dec 30, 2008 | 08:28 PM
GMCtrk's Avatar
who did the tune?
My lq9 with pacesetter/ory, ported tb, and wheatley tune made 305/328 2nd gear verter unlocked
Mine's 2wd though.
Old Dec 30, 2008 | 08:29 PM
GMCtrk's Avatar
Oh yeah, how does he like the torquer 2?
With that cam in that setup with the converter locked I'd expect 350-370rwhp or so.
Old Dec 30, 2008 | 11:27 PM
thats what we thought.. it pulls hard up top.. The tune was done by a local guy.
Old Dec 31, 2008 | 08:15 AM
KLUG'S SS's Avatar
FormerVendor
Hmm, those numbers seem awfully low to me. I would think that should be good for at least 350hp.
Old Dec 31, 2008 | 09:07 AM
hirdlej's Avatar
Well, my 218/224 cam in my 6.0L was 360RWHP and 400RWTQ
Old Dec 31, 2008 | 09:22 AM
KLUG'S SS's Avatar
FormerVendor
Exactly! So I would expect alot better from that setup. Nice numbers btw, I have a cam very close to what you have in my LQ9 and it runs out pretty damn good.
Maybe an issue with the tune.
Old Dec 31, 2008 | 09:35 AM
First pull made 305 hp then he got the AFR to like 12.7 and with 27-28 of timing. then it made the 311. anymore timing over that would make it loose power. He said that maybe a cable/spark plug could of not been working and make it run on 7 cylinders. thats the next thing were going to check. Also hes running 08 NNBS spark plug wires with tr-6 if that has anything to do with it?
Old Dec 31, 2008 | 12:40 PM
GMCtrk's Avatar
Do remember that you have an NV3500 and do not spin thru a transfer case. Traditionally, the difference between a T56 and a 4l60e on the dyno in an f-car is roughly 20rwhp. So take that into account.
If the truck was running on 7 cylinders, I really think you'd notice it?? After a header install, I forgot to fully install one of the plugs on the coil and it was running on 7 cylinders and it was stumbling and bumbling. Maybe if it was like that for a while though the computer would adapt and it would run smooth. I don't know.
Old Jan 2, 2009 | 07:44 AM
norris_83's Avatar
similar mods, similar dyno number but mines a 5.3.... it does look too low, u should be at least 20hp/20tq higher then what I'm at...
