Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
04 5.3 bolt on + big cam , under 290hp ?
Old Jan 22, 2014 | 06:10 AM
Boost-freak's Avatar
Default 04 5.3 bolt on + big cam , under 290hp ?
hi everyone
i have a 5.3 with bolt on and 231-239 617-621 113lsa stock heads and stock intake and a cluch fan .
now this numbers are taken on a pull till 5600rbm , i have set my cut off to 6500rbm
i know i should at least be around 310+ hp 326tq , i have with me now a set of 799 heads and a NNBS intake , what is your recommendtion on this compo , how much to mill from heads , am i better off with another intake , i ordered nelson fan harness and soon it came it will be mounted with 05 oem e-fans
here the dyno pull chart :
tune was done on street maybe after 1 month i will do it on a dyno with the same tuner
Old Jan 22, 2014 | 07:53 PM
oakley6575's Avatar
Jesus, who spec'd the parts for this build?
Old Jan 23, 2014 | 11:56 AM
what is wrong ? tell me so i can fix it
Old Jan 23, 2014 | 01:13 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
Port and mill the 799s. The NNBS intake and E-fans will make a huge difference. I would suggest a slightly smaller cam for a 5.3. Might not make as much peak HP, but it should make for more torque early in the powerband.
Old Jan 23, 2014 | 01:34 PM
oakley6575's Avatar
This^^. The cam is pretty close to the same cam I ran in my 408. It is way too big for your 5.3 IMO. But you have some good parts to add that will make it run much better.
5.3Okasai
Mar 9, 2022 01:07 PM
steves86ta
Jul 28, 2015 10:21 AM
low2001gmc
Jul 23, 2015 05:10 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
EscaTruck
Jul 20, 2015 11:42 AM
