Drivetrain & Suspension Chassis | Transmission| Driveshaft | Gears/Rear End/Differential | Traction Aids
One scary lightning! MUST SEE
Old May 17, 2007 | 09:47 PM
alteredimage's Avatar
Default One scary lightning! MUST SEE
So we got a call from the Ford dealer the other day wanting us to look at a truck they had taken in trade. Aparently it was all fine untill they had to drive it around the lot then it stoped going up! What we found was beyond bad it was plain ugly.
Pass side spring hat ripped right from the frame. Thus crushing the brake line, popping the bag, kinking the airline. Glad it was just in the parking lot. Imagine going down the highway loosing control of the dteering then loosing brakes smashing into a gaurdrail. Sounds like fun.
The driversside isn't much beter. Notice the ABS wires.
Did they run out of steel or think it was not needed?
Splice?
Old May 17, 2007 | 11:45 PM
Dock Rocker's Avatar
Two Words
HACK JOB!
Old May 17, 2007 | 11:57 PM
203Cree's Avatar
My thoughts exactly.
Old May 18, 2007 | 12:52 AM
nonnieselman's Avatar
Looks like somebody needs some welding lessons.......
Old May 18, 2007 | 12:55 AM
RandomHero's Avatar
looks like good penetration on the welds. A+
Old May 18, 2007 | 06:52 AM
krambo's Avatar
I don't see a problem ...Nothing a little JB Weld can't fix.
Old May 18, 2007 | 07:40 PM
So here is a little more of the horror.
Bag mount on the LCA
What do you think out of the castle nuts that had cotter pins did they forget to bend them over or did they know it would be coming back apart?
Upper bag cup Pass side
Upper bag plate drivers side
Old May 19, 2007 | 01:55 PM
Start of the repair work
Removing the lower bag plate was easy a light tap with the hammer and it fell right off
Control arm cleaned up.
Lower bag plate cut from 1/4" plate
Plate welded in
Frame starting to get cut out
Look at the big hole!
Frame remade and upper bag plate welded in
All painted purdy
All back together
Now to redo the notches, rewire it and rebuild the frame for the panhard bar.
Old May 19, 2007 | 04:46 PM
Wilde Racing's Avatar
How do I change this text
All I see are red X's...........................
Old May 19, 2007 | 10:16 PM
Well somebody hacked my website and erased all of the gallery picks 100 vehicles worth. Looks like they were not to pleased with the photos
