Drivetrain & Suspension Chassis | Transmission| Driveshaft | Gears/Rear End/Differential | Traction Aids
Lightning rims
Old Feb 20, 2006 | 11:36 AM
nojpsht04rst's Avatar
Default Lightning rims
Does anybody know if the wheels off of a newer lightning will fit onto a 92 f150. thinking of makin an old school lightning with a supercharged 5.0 and lightning emblems and the wheels would just finish off the truck.
Old Feb 20, 2006 | 11:49 AM
203Cree's Avatar
Depends on what size studs you have. Measure your wheel studs and post up what you find out, then we can figure out which wheels you can run. Bolt pattern should be the same, it's just there's two different stud sizes used on Lightnings.
Old Feb 20, 2006 | 02:58 PM
Joey5.4L's Avatar
Bolt pattern on a 92 F150 will be 5x5 1/5 and 97 up F150s are 5x135mm.It can be done, but you will have to change your bolt pattern.
Old Feb 20, 2006 | 04:04 PM
203Cree's Avatar
Ya know, I didn't even think of that. You'd have to run adaptors. You're pattern is 5-139 where as ours is 5-135.
Old Feb 20, 2006 | 09:35 PM
thanks for the info i was really set on doing it too.
Old Feb 20, 2006 | 10:05 PM
203Cree's Avatar
Not gonna give up are ya? It can be done bro, it's not a biggie. Tell ya what. Before you get down about doin it, lemme search around some more. There's several guys that have done. I'll see what I can find for ya. Sound Good?
Old Feb 20, 2006 | 10:17 PM
203Cree's Avatar
Hey, I sent ya a PM.
Old Feb 21, 2006 | 11:59 AM
thanks guy now i want to get it done. when its finished i'll post pics thanks for the help. the adapters wont push the wheels out too far will they?
Old Feb 21, 2006 | 12:50 PM
203Cree's Avatar
You can get pretty slim adaptors. They will probably push them out some, but it's all gonna depend on how thick of an adaptor you get. Did you get the PM I sent you?
Old Feb 21, 2006 | 03:18 PM
yeah i did thanks i appreciate it.
