Drivetrain & Suspension Transmission | Gearing | Traction
Wheel hop from hell
Old Sep 7, 2006 | 10:09 AM
VortecHOjunkie's Avatar
With that much drop from the spring under your pinion angle is going to be all messed up. If you haven't changed it take a look at it. The pinion will probably be pointed slightly above horizontal. Pinion shims are cheap. Shim the leaf springs until your pinion angle is slightly below horizontal. That should help. I would imagine you get some driveline vibration at high speeds if you haven't fixed this already. My truck begins to get a slight vibration above 90 with just shackles and the overload removed. Traction bars definately cure the wheel hop, but cost a little more. I put a set of lakewood slapper bars on my truck for around $200. They are longer than normal and custom fit for my truck.
Old Sep 9, 2006 | 07:37 AM
LS1Silverado98's Avatar
12 Second Club
I will check my pinion angle later today. Whats the difference between Lakewood slapper bars and CalTracs? I know that cal tracs are $339.00 and the ones your are talking about are a lot cheaper. Do you have any pics, and will they work on my truck which has been lowered?
Old Sep 11, 2006 | 08:34 PM
ColtSteele's Avatar
After I flipped my rear axle I got wheel hop from he77... a little pinion angle adjustment and some spring clamps for good measure and... no more wheel hop. Check your pinion angle out. Good luck.
Old Sep 17, 2006 | 07:11 PM
12 Second Club
Yeah, the pinion angle is def. off. Its pointing up. Where do you get shims to correct this? I was just jacking the truck up and checked tonight. Ive also got Cal-tracs im going to install. My problems should be fixed soon!
Old Sep 18, 2006 | 05:53 PM
12 Second Club
There are two different size shims. 4 and 2 degree. Which ones do i need with the flip kit?
Old Sep 18, 2006 | 06:00 PM
12 Second Club
[IMG][/IMG]
Here's a pic I just snapped. Ive gone everywhere in town and cant find the damn tool i need to measure the angle.
Old Sep 20, 2006 | 01:37 PM
Cummins's Avatar
WOW, Thats way off. That is definatly your problem right there, the Pinion angle needs to be pionting just a tad under horizontal like mentioned above.
Old Sep 22, 2006 | 12:08 PM
if u have a flip kit im almost positive the caltracs wont work... i could be wrong tho i guess
Old Sep 24, 2006 | 08:16 PM
12 Second Club
Calvert Racing makes a set for flip kits and lowered applications. I got them installed yesterday. Also corrected my pinion angle. Wheel hop is all gone!
project-pegasus
Sep 18, 2015 08:22 PM
ClintBeastwood
11
Sep 13, 2015 11:49 PM
George C....
Sep 11, 2015 04:45 PM
dselby25
Sep 11, 2015 05:03 AM
the owl
Sep 4, 2015 04:09 PM
