Drivetrain & Suspension Transmission | Gearing | Traction
Vibration at 100 mph
Old Apr 16, 2010 | 10:05 PM
bagz's Avatar
Default Vibration at 100 mph
Feels like u-joints/drive shaft are vibrating at 100-103 mph then stops as speed increases. Starts at the same speed when slowing down from 105+
what is this from and how to fix?
Old Apr 16, 2010 | 10:37 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
moved from the GMT900 section....
first of all, it would help to know your truck/mods
Old Apr 16, 2010 | 10:47 PM
bagz's Avatar
2010 sierra 2" shackles in the back and removed the 1 1/2" blocks. I though it might need a pinion shim but others have done it said it's not needed
Old Apr 16, 2010 | 11:05 PM
trever1t's Avatar
some may and some may not. You can try 2* shims and see if it helps or worsens.
Old Apr 16, 2010 | 11:43 PM
Atomic's Avatar
I have a gauge for that
if its not the pinion its probably tires or driveshaft
Old Dec 15, 2010 | 05:19 PM
fastjweb's Avatar
is it a crew cab? the one piece long driveshaft will do it
Old Dec 15, 2010 | 05:22 PM
GMCtrk's Avatar
can someone explain/show where the shims are supposed to be placed?
Old Sep 7, 2012 | 10:01 PM
abey15's Avatar
Which gears u have? I've found out that the one piece drive shaft in fact will do that especially after I swapped to 410s(the drive shaft having to spin faster)
Old Sep 7, 2012 | 10:09 PM
cammed00's Avatar
Damn man you raised the dead with bumping this thread, lol it's from 2010.
Old Sep 8, 2012 | 07:47 AM
bluecajun5.3's Avatar
11 Second Truck Club
The op has 3.73's.
I just got mine tuned and it did the same right after 100.
It's a 1 piece aluminum d/s and truck is leveled 2" in front.
