TIME SLIP DATABASE
wish me luck, time to step it up a little
Old Sep 24, 2006 | 10:36 PM
  #31
kbracing96's Avatar
For your efilive problems, did you down load the latest usb drivers for it when you put the software on your new laptop? I had problems like that when I didn't do that.
Old Sep 25, 2006 | 01:00 AM
  #32
02sierraz71_5.3's Avatar
Wow thats alot of kr especially for race gas
I wonder if you still get that without the N2o?
EGT guage?
I see what you mean about the fueling, pump issues?
dual tank setup?
Old Sep 25, 2006 | 06:22 AM
  #33
parish8's Avatar
single digit dreamer
i got the latest drivers off their site.
i only spray for about .3sec so i dont think the nitrous is the problem. no egt gauge. i have the dual intank fuel pump set up. i am prety sure a fuel filter and taking the power wires to the alternator will help.
Old Sep 25, 2006 | 06:40 AM
  #34
TouchOfEvil04's Avatar
Good luck getting it all fixxed up man.
Old Sep 25, 2006 | 09:39 AM
  #35
quicksilverado's Avatar
Have you considered a transbrake to build boost off the line?
  #36
FMOS Racing's Avatar
Originally Posted by parish8
i think every run was against a 10sec lightning. the run where i ran a 10.3 was against the twin turbo one with a blow thru carb. that was a very clean set up. he had ran a pile of 10.24's that day and guess what. he did it again. his 10.24 took my 10.3. my rt was a little better than his and the diference at the end was .0116 with him in the lead. it was a fantastic race and a lot of fun.
Dave said it was the best race he's ever had. Still talking about (as I type, even).
Was nice to meet you. Would've liked to have talked to you more but you were always (at least when I saw you) surrounded by an entourage. You guys took some AWESOME pics! I love this one of my tailgate:
Old Sep 26, 2006 | 01:00 PM
  #37
parish8's Avatar
i checked the voltage at the alternator and at the battery and it is exactly the same, even if i rev it up. i dont see any point in moving any wires around.
i swaped out the fuel filter. the new one i could blow thru easy. with the old one even after leting it dry out for a couple of hours was very dificult to blow thru. i cut it open and to me it looks like the filter paper is full of mud. not where the flutes are packed or anything but if you wipe a paper towel on the elemet it leaves what looks like mud on the paper towel. i hope this fixes the fuel problem
Old Sep 26, 2006 | 08:20 PM
  #38
litreddevil's Avatar
Banned
i change my filter every 3 m. had a friend that blew his motor and that was the only thing they found that could have did it
Old Sep 26, 2006 | 09:57 PM
  #39
Jim
Have you considered running higher gauge wire to the pumps. I would guess that the current wiring is 16 gauge - 12 or 10 gauge would make HUGE difference. Im sure the voltage is the same at the battery or at the alternator. You will have to measure voltage drop at the pumps. Typical voltage drop for wiring that long is 1-2 volts.
Good Luck - (You can always add a boost activated voltage booster)
Old Sep 26, 2006 | 10:04 PM
  #40
nonnieselman's Avatar
I agree what Jamesbond said esp. If you have stock wiring. I dont know how your Dual pumps are wired. But if you ran some , say 10ga back there, you should get "full" voltage back there.
Good Luck to ya man!!!!
I have a Fuel Filter sittin on my back seat i got to change..
