TIME SLIP DATABASE
what's the cam only CC record/rules?
Old Nov 1, 2010 | 08:37 PM
iamkeniff's Avatar
Default what's the cam only CC record/rules?
well...ive looked at the fastest truck list ive but i cant really see too much crap on my iphone. anyways...what's the fastest cam only CCSB? does milled stock port heads kick me out of the running for that record? they are milled 20thousandths, stock ports, stock intake, stock TB, stock MAF. stock 60e with billet 1-2/4th gear servos ONLY. pacesetter LTs/OR-y/3" exhaust/36" muffler. only thing done to the suspension is spindles/removed lift block/shackles/leaf clamps on the front of the leafs. stock shock all the way around. tailgate up, tow hitch and all.
mods are in the sig but i cant tell you the weight of my truck, i know it's heavy as hell though.
it has 265/70/17s up front and 28" M&H DRs as track setup.
i also carry a 3 ton jack, breaker bar, socket, other crap for when it breaks down
maybe someone can shed some light on this record considering i never seen it posted yet.
thanks.
Old Nov 1, 2010 | 09:28 PM
Phantom's Avatar
11 Second Club
what record?
Old Nov 1, 2010 | 09:30 PM
skoal bandit's Avatar
I bet your pretty close to the fastest, for now. I think when them 6.2/6l80e boys start modding like yours, they will be faster. You need a 6l80e.
Old Nov 1, 2010 | 09:35 PM
iamkeniff's Avatar
just asking is there a record.
"stock bottom 5.3"
"cam only hemi" etc.
there is a cam only 6.2/6spd that went 12.4s if i recall....but i cant swap in a 6spd without pulling the harness/cluster/shifter and who knows what else. im jist waiting around to see if someone will do a 6spd swap in our trucks
Old Nov 1, 2010 | 09:38 PM
viciousknid's Avatar
Where's the Beef?
why not just do what you want to do to your truck. If you want to only do heads/ cam mods then only do those.
Old Nov 1, 2010 | 09:46 PM
iamkeniff's Avatar
bc i will end up pulling the motor later on and having it rebuilt to a 9:5:1 compression. i want to go 76mm i believe. but im enjoying the way this bus runs now!
Old Nov 1, 2010 | 09:48 PM
Where's the Beef?
then what does a cam only record matter? For what it's worth I think cam ONLY means the ONLY mod you've done is cam. cam and milled heads would be cam and heads only
Old Nov 1, 2010 | 09:50 PM
dlt76028's Avatar
This guy runs 12.4s on DR and 3.42s.
https://www.performancetrucks.net/fo...d.php?t=429381
Old Nov 1, 2010 | 09:56 PM
iamkeniff's Avatar
yeah thats who i was talking about! his shiii is fast! i asked him about how big his cam is but he didnt pm back.
i was thinking milled stock ports wouldnt count but i guess it would.
Old Nov 1, 2010 | 10:05 PM
dlt76028's Avatar
its a 3000 converter with a 226/226 581 cam
