TIME SLIP DATABASE
what will it run?
Old Jun 7, 2009 | 09:29 PM
03lowriderss's Avatar
Default what will it run?
Kinda hard to search since so many people have different mods.
What do yall think that i would run?
4270 LB race weight
mods in signature (does not include my tb spacer... hehe)
In 85-90 degree weather, no slicks
Old Jun 7, 2009 | 09:37 PM
A Low Dime's Avatar
13 Second Truck Club
On those tires with those mods, high 8's low 9's.
With a stall and slicks mid 8's.
Old Jun 7, 2009 | 09:40 PM
got a 1/4 mile track here
Old Jun 7, 2009 | 09:42 PM
bluecajun5.3's Avatar
11 Second Truck Club
14.00's @ 97
Old Jun 7, 2009 | 09:48 PM
RandomHero's Avatar
They're going to let you run your truck with shaved handles? I assumed that's what you meant by "bagged and shaved"
Old Jun 7, 2009 | 09:53 PM
tommy1005's Avatar
I'm gonna say closer to high 14's or low 13's with air bags and lexanis. Lot of extra weight to be dragging around and may or may not hook up depending on your tires and what kind of airbags you have in it and how they are set up.
Old Jun 7, 2009 | 09:56 PM
RandomHero's Avatar
Did you mean high 13s and low 14s?
Old Jun 7, 2009 | 09:59 PM
A Low Dime's Avatar
I didnt even realize you were in MN, whats the altitude up there?
Old Jun 7, 2009 | 10:37 PM
idk on altitude, you would be surprised, the bag job dont add much weight, forward four link with bags over the axle, if i give it a "gasser" like angle slightly higher in the front and firm pressure in the back she would hook real damn good with the 5.3 that was in before.
Old Jun 7, 2009 | 10:47 PM
GMCtrk's Avatar
4270 race weight is about 500lbs less than my race weight in a full weight sans spare tire and hitch 2wd ecsb. With headers, prc stage 1 ls6 heads, stock cam, stock trans/converter, and 4.10/trutrac on 285/60/18 proxes it did 14.06 @ 96.6. 60' was about 2.18 ish if I remember correctly and that was on a perfect 1/2 to 3/4 throttle launch...trying to go full throttle off the line was a joke with the street tires. So given you weight advantage, but stock heads, I'll say around 13.9-14.0 due to the temps. I ran in 50 degree temps, DA was right around sea level. But I've also found out recently that I've got problems and cant get more than 19 degrees of timing, so I never saw the full potential. I would not be surprised to see a 13.7 or 13.8
