TIME SLIP DATABASE
What gear for a good burnout?
Old Apr 13, 2009 | 10:41 PM
BigCountryx's Avatar
Default What gear for a good burnout?
I just got a set of Drag Radials and was wondering if I should hold second gear for a good burnout to prevent shifting while in the box or if I should just go with Drive (3rd) What do you do to heat your tires out the box?
Old Apr 13, 2009 | 10:47 PM
Mangled03gmc's Avatar
Baltimore Whore
I always put it in 2nd .. No reason to go to third unless your set up with a line lock IMO, hard on the brakes..
Old Apr 14, 2009 | 06:00 AM
sickREDsierra's Avatar
i start in 1st, after it shifts i hold it in 2nd.. my tranny will start in 2nd if i hold the shifter there from the start.
Old Apr 15, 2009 | 05:54 PM
silver-mod-o's Avatar
Hunt&Fisherator
I start in 1st and let it shift to 2nd in the box.... then roll out.
Old Apr 15, 2009 | 06:02 PM
nonnieselman's Avatar
when was the last time you did a burnout?
i just hold it up to about 80 and roll out of it now. ive been learning.
Old Apr 15, 2009 | 06:11 PM
RandomHero's Avatar
I like to let it shift into 2nd then 3rd then downshift to 1st and into 2nd again. I feel it's the best thing for my transmission.
Old Apr 15, 2009 | 06:23 PM
GMCtrk's Avatar
do you guys floor it on the burnout? I just had mine in drive and was doing about half throttle maybe a little more. The first one it never shifted out of 2nd and the next one I think it went into 3rd because my rpm's dropped down to about 3000 and I couldn't figure out what was going on
Old Apr 15, 2009 | 06:29 PM
i hammer on mine and when it gets to about 80 i ease out of it and then let it roll out. Thanks for to some instructing from JoesphK i actually hooked last night at the short track.
Baltimore Whore
No I have never floored it, no reason to really.. Just get them going pretty good on the first one of the day, if you sit a long time in between runs.. Roll it out of the box at a lil more then half throttle.. at least is how I do it
Old Apr 15, 2009 | 06:32 PM
GMCtrk's Avatar
spinning faster = more heat ?
