TIME SLIP DATABASE
what do you all think?
Old Jan 5, 2007 | 05:19 PM
BlackPearlZ71's Avatar
Default what do you all think? *UPDATE*
wats up guys! just want to see what you all think...my best run in my truck is a 13.84 but with a slipping transmission, quick tune(not widebanded), and good year street tires (225/55/17)...my transmission is currently in the shop getting beefed up including servos, clutches, shift kit, the works.
as soon as my truck is ready i'm going to get it widebanded and run it with some 26' slicks hopefully. what do you all think i'm going to run with my new transmission?
*UPDATE*
i am officially also installing a tci 3600 stall. what quarter mile times should i see with my setup and slicks?
Old Jan 6, 2007 | 09:08 AM
litreddevil's Avatar
Banned
man it all depends on how bad was it slipping,what was your 60' times 1/8 mile and mph
Old Jan 6, 2007 | 10:36 AM
onebadrubi's Avatar
are you stepping up your converter to an aftermarket or larger stalled converter?
Old Jan 6, 2007 | 12:14 PM
for now the stock converter.
Old Jan 6, 2007 | 12:15 PM
actually i got a good 60ft for having my stock converter, it was a 2.0...but wen my 2nd gear was going to kick in it felt like forever for it to go in.
Old Jan 6, 2007 | 05:45 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Maybe a 1/10th faster, the trans isnt going to make that big of a difference and with a stockish truck like yours a WB tune isnt going to do much, you can tell via logging with HPT looking at the mv your O2 sensors are reading.
Old Jan 6, 2007 | 06:33 PM
rrrright....
Old Jan 6, 2007 | 07:22 PM
Banned
i would have to disagree with the slipping trans part i think with a good trans ,tires,and the tune stright you'll pick up 4 tenths just when you go back to the track send me a pm before hand
Old Jan 7, 2007 | 04:03 PM
1slow01Z71's Avatar
Originally Posted by LaBlackPearl
rrrright....
Dan is a very experienced tuner and I bet he does the same thing that Allen Nelson does on my truck, you can look at the mv output of the front two O2 sensors and that will tell you your A/F very close. If it was only slipping on the shift then there isnt much to gain there, if it is slipping through the whole gear then maybe so. I have already gone through that stage with tuning and slipping trans and I didnt gain as much as I thought I would. If you didnt spin off the line with your street tires then pretty much what you are going to gain is spinning a shorter tire. I missed the part about going to slicks the first time I read through so I would say 2-3 tenths then since I think the slicks will make the biggest difference down the track since you will have better leverage on the tire.
Old Jan 7, 2007 | 05:43 PM
there u go, i figured u probably missed the part of the slicks thats why i was like "rrrrright"...yeah thats wut i personally think i'm going to increase is about .2secs better...as soon as my truck is out hopefully by the middle of this coming week i'll let Dan play with it all he wants until its running perfect and i'll keep you guys posted on my new times.
