TIME SLIP DATABASE
Went to the Track Today
Old Oct 4, 2008 | 04:36 PM
buzzkillwill's Avatar
Default Went to the Track Today
Maons /Dixon Dragway
Temp: 68
humidity 60%
I made two runs:
R/T... .528
60... 2.366
330... 6.558
1/8... 10.052
MPH... 70.89
1000... 13.017
1/4... 15.572
MPH...87.53
Braked to 1,000RPM- then mashed the pedal
R/T... .304
60... 2.323
330 ...6.455
1/8... 9.891
MPH... 72.05
1000 ... 12.820
1/4... 15.359
MPH... 87.74
Right headlight removed, engine temp was reading 180*
Braked to 1,000 RPM- then mash and go.
I executed both runs exactly the same- only difference was headlight removal and cooler engine temp. In between the runs, I opened the hood, and in the staging lane, I turned the truck off and left it nuetral and coasted, until there was only two cars in front me. Then I started it.
I'm thinking with a good tune, which I'm getting next week, and my new(new to me) intake, I'll break 14's, easily. Add some taller gears, 3.73's or 4.10's and I should be able to bring that even lower and (possibly) get my 60' times closer to 2.00.
My truck is running rich, which I know is hurting me and hurt my times today, but I just wanted to see where I'm at, time wise.
Only ran twice because survival instincts kicked in, I got hungry and needed food!
Def. had fun running and spectating.
Old Oct 4, 2008 | 05:59 PM
95 bright teal's Avatar
Looks like we have the same setup! i ran last night and pulled a 15.425, 2.346 60ft.
do you know what elevation the track was?
Old Oct 4, 2008 | 06:20 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
tune might get you there (15's)
If you swap gears get an lsd in there at the same time. Cutting 2.0 60's may require somthing other than street tires
Congrats on the runs!
Old Oct 4, 2008 | 06:38 PM
Originally Posted by 95 bright teal
Looks like we have the same setup! i ran last night and pulled a 15.425, do you know what elevation the track was?
The elevation is 550ft. Congrats on the good run. You ahve lower gears, which I would like to get.
LSD-Limited Slip Dff.?? Isn't that what the G80 is? You're probably right about the 2.0's, but I was able to do it in my previous truck, so we'll see- Something to shoot for.
Old Oct 4, 2008 | 07:28 PM
trever1t's Avatar
no, the g80 is a gov-loc not a lsd and not really good for the track, plus they are a weak link and prone to damage.
Old Oct 4, 2008 | 07:37 PM
ahh, figures...lol I know with the gears I have, I'm not putting much stress on it- Pulls like slug off the line.
I'll look into the LSD. Where's a good place to get some gears and LSD. Seems like I saw some on one of the site sponsors...
Hey, at least I ran what I thought I would, low 15's.
Old Oct 4, 2008 | 09:51 PM
You will want lsd, my truck could not hook real well, hence the same 60ft, and it was like 85 at 1200ft.
to get that 2.0 you will need more than just gear, from what ive seen you need drag radials or slicks and a stall.
Old Oct 4, 2008 | 09:53 PM
ZO6Ted's Avatar
Very respectable run, congrats!
Old Oct 4, 2008 | 09:57 PM
outlawz2004's Avatar
Good runs. That reg cab will be in the 14s before you know it.
Old Oct 4, 2008 | 10:05 PM
Heat and elevation, two things hard to overcome- sitll had a good run though.
Thanks guys. I had fun, although I was asleep at the light on my first run. lol
