TIME SLIP DATABASE
Went to the track the other day...
Old May 23, 2006 | 04:41 PM
onebadrubi's Avatar
Default Went to the track the other day...
Local track is only 1000ft.
It was 90 degrees with 80-85% humidity. HORRIBLE weather!
on motor with passenger(he wieghs 200lbs) ran 12.1. Cutouts open and headlight removed.
THen hook up the bottle with 800 bottle pressure.
Im was spraying threw my controller. at 3000rpms 60% and 1.5 sec build time to 100%....100 shot. I started here with hopes of palying with rpms and build time and such.
Ran 11.7.
I was cutting 2.1 60ft all 3 of my runs.
3rd run I ran with the N20 but I did brake stall a little higher and spun a little more out of the hole. Ran 11.8
Im really dissatissfied with the times but I could have easily played with the controller settings and got it lower!
What does everyone think of my times?
Street tires
LT's
Cutous
4.10 w/G80
intake
W4ME tune
A very tight 2800 stall that is flashing ot like 2200 if that.
then the 100 shot for the last two runs
Old May 24, 2006 | 12:05 PM
MrDestinE's Avatar
Keep it up.... I am sure you will get it down a lot lower...
If you ran 12.1 N/A and then dropped 200 lbs seems like you should see High 10s with the 100 shot..
TJ
Old May 24, 2006 | 02:03 PM
onebadrubi's Avatar
but im runnin the 100 shot threw a controller. If it was a button perhaps towere 100 shot from traction to 1001ft I could see it. But see its not activating till certain rpms and hten its only comin in at like a 60 and building to a 100.
Old May 24, 2006 | 08:39 PM
MrDestinE's Avatar
I really cannot say about higher shots...and controllers but I do intend to leave the line with as high a shot as I can on the big drag radials, 150 if it will hook up..... I would say get far more aggessive with it.. how is your traction???
TJ
Old May 24, 2006 | 11:19 PM
onebadrubi's Avatar
what do you mean by actually spraying off the line? Mine sprays as soon as the TPS indicated WOT.
Old May 25, 2006 | 02:23 PM
hog's Avatar
hog
Spraying off the line means exactly that, launching the truck with teh nitrous flowing.
the whoel purpose of a controller is so that you dont lose traction when you leave the starting line. You start off as a 60 shot then it builds to a 100 hp shot.
Sounds like you need to play with teh controller a bit.
peace
Hog
Old May 25, 2006 | 04:06 PM
Rhino79's Avatar
9 Second Club
The Hauler said you can spray him and he will run you N/A with the new motor (cammed 6.0l).
Old May 27, 2006 | 01:30 AM
onebadrubi's Avatar
HAHAHAHA....tell him any day of the week....IF I get to use his slicks and he uses street tires......
Ryan.....I a few races already lined up for yall(HONDA, HONDA, HONDA, HONDA, HONDA, THEIR are more honda's runnin around here then the fast and the furies. I **** you not.)
onebadrubi's Avatar
OH btw I havnt got the currage to get back on the street after Little rock gave out 12k$ worth of racing tickets in one night at fouche, otter creek, and somewhere else.
Old May 27, 2006 | 02:28 AM
TouchOfEvil04's Avatar
Holy S$%T!!!!!!!!!! I can't say that i blame you lol.
