TIME SLIP DATABASE
went to the track and not happy
Old Oct 8, 2009 | 08:23 PM
  #21
LsxCody's Avatar
I don't think changing exhaust would be the answer
Old Oct 8, 2009 | 08:43 PM
  #22
Most Hated's Avatar
then what can it be
Old Oct 8, 2009 | 08:44 PM
  #23
Most Hated's Avatar
can this be it
That cam has a LOT of exhaust duration, it may have been purpose-designed for a more restrictive exhaust.
Old Oct 8, 2009 | 09:50 PM
  #24
slowlsx's Avatar
Originally Posted by Most Hated
can this be it
you should really ask patrick. when he spec'd you the cam did you tell him you were goin to run dual exhausts?
something is definately wrong because i ran mid 11's with a 5.3 and 150 shot.
Old Oct 8, 2009 | 11:08 PM
  #25
Most Hated's Avatar
i check my sheet and i put dual 3 inch x pipe so i dont know where the problem stands
Old Oct 9, 2009 | 01:31 AM
  #26
Spoolin's Avatar
GFYS and STFU
I know this sucks but it's kinda interesting. I would suggest, since it's easier to swap the exhaust back to do that and go back to the track. If it does better or worse it will tell you if it was your cam or not.
Old Oct 9, 2009 | 01:49 AM
  #27
Most Hated's Avatar
yea that's what im probably going to get done by the week end and take it to the track next wed, ill keep yal posted to see if theirs a diff , i hope so
Old Oct 9, 2009 | 01:57 AM
  #28
Most Hated's Avatar
y is that u think that ? im curious , whats you all's opinion's on the exhaust
Old Oct 9, 2009 | 02:11 AM
  #29
Spoolin's Avatar
GFYS and STFU
Some people think 3" duals is too big and not enough restriction. However...I have a 3" x-pipe and open headers out both sides of my truck and it only made 4 rwhp more than when I closed the cut-outs and went into a 2-1 muffler a resonator and out a single 3" tip.
Old Oct 9, 2009 | 05:59 AM
  #30
Daryn's Avatar
Formerly darynC-10/23/10
okay so let me get this strait. gt2 can with the radix and that converter you have went faster?.... and now with the larger cam it goes slower.
is the converter "loose" or tight? that converter may be hurting you.
i would ditch the PI and get something that has a higher str.
and drop that crazy 4k to maybe a 3600.
