Went to Coastal Plains Dragway today
So I entered the car show. Some of the goofyest looking cars won. Anyways my check engine light came on after about 2 passes. I took it to get the code read, it says that bank 1 and 2 rear o2 sensors have low voltage. What does this mean? I have to figure this out before the end of the month when my inpections due, or the state will fine me $250. It was 96* out, my best run was a slow 14.7 at 93.72mph. I felt like I was spinning off the line aswell. The guy that owns the lightning that beat me in the video was talking **** to me. I just laughed when he told me he was running like 14 pounds of boost and he was in the mid 13's. Would the heat really effect it that much.
Poor cat efficiency i think. Also you could just have them turned off, I had kyle do it when he tuned my truck after the swap. I believe they do a visual inspection, then check for active and inactive codes. So if you have the rears turned off and you have no other codes you should pass. Just my .02 cents, Also your truck looks nice, you engine bay looks freaking perfect from what i could tell. Its funny how guys with lightnings talk ****, they have blowers and bigger motors, they should be faster, but in alot of cases they arent.
Dustin
Dustin
Rob
Dustin
Dustin
i would just leave the O2's alone, there isn't a reason with your mods to not use them all 4. Your truck looks great. One suggestion would be to put the Silverado SS tailgate spoiler piece on there. Not picking at your truck, just commenting. I really like the smooth red look you have there. Not a bad time for your truck either in that heat assuming you don't have many mods.
Did you ever decide on doing the cam install? I knwo of a local forum there that has some good guys as members and help each other out with mods quite often. I'll PM you a link
Rob
Vortec350ss
Jan 12, 2016 10:36 PM
