went to the 8th today............
#51
Is this a 60e or 80e? You might need to back down the MPH shift point... BTW what rpm are you shifting?
#52
does it shift normal or does it hit the rev limiter???? make up your mind. it can shift normal under light acceleration and slam the limiter at WOT due to slipping clutches. i give your transmission another 2 months or so depending on how you drive it.
#57
You can command the shift much lower (5500RPM) for example,it still hits the rev limiter.
The PCM commands 3rd gear shift at WOT,but it does not happen.
Tried everything to get to shift at WOT but still hits the rev limiter.
Put the stock tranny setting and still does the same thing.
#59
#60
doesn't know what quit means
