TIME SLIP DATABASE
went to the 8th today............
Old Sep 28, 2009 | 04:03 PM
  #51
BlackGMC's Avatar
Resident Retard
Originally Posted by lablackbeast
i dont have a trans cooler and i was thinking that could be the issue what yall think?? its a 3800circle d
Well that is not very intelligent.... No offense.... You spend a ton of money on the 6.2, heads, a nice TC, and you don't add a $100 tranny cooler....
Is this a 60e or 80e? You might need to back down the MPH shift point... BTW what rpm are you shifting?
  #52
TXsilverado's Avatar
does it shift normal or does it hit the rev limiter???? make up your mind. it can shift normal under light acceleration and slam the limiter at WOT due to slipping clutches. i give your transmission another 2 months or so depending on how you drive it.
Old Sep 28, 2009 | 04:06 PM
  #53
man, only a 1.85 with the circle d 3800??? whats up with that?
Old Sep 28, 2009 | 04:26 PM
  #54
lablackbeast's Avatar
doesn't know what quit means
stock suspension and just doing 1500 rpm stall..........it do shift but not at WOT o ans my shift point is 6450
Old Sep 28, 2009 | 04:28 PM
  #55
BlackGMC's Avatar
Resident Retard
does it shift fine at WOT with street tires?
  #56
say good bye to your transmission while its still getting you down the road.
Old Sep 28, 2009 | 04:34 PM
  #57
Wheatley's Avatar
Truck Sponsor
You can command the shift much lower (5500RPM) for example,it still hits the rev limiter.
The PCM commands 3rd gear shift at WOT,but it does not happen.
Tried everything to get to shift at WOT but still hits the rev limiter.
Put the stock tranny setting and still does the same thing.
Old Sep 28, 2009 | 04:35 PM
  #58
no it doesnt...........
Old Sep 28, 2009 | 04:37 PM
  #59
BlackGMC's Avatar
Resident Retard
So that would make it a mechanical issue right? What year truck is it?
  #60
yea i know charlie i think is the cooling cause last saturday it was kinda cool and it shift to third like nothing on D and you know it normally dont do that...........
