TIME SLIP DATABASE
went to the 1/4 mile friday at HRP
Old Nov 1, 2009 | 11:33 AM
  #131
lablackbeast's Avatar
doesn't know what quit means
Originally Posted by skeet
ok my bad, didnt know you kept going back.
well went for the cam swap then the injectors and then the 1 7/8 headers around 4 times............
Old Nov 1, 2009 | 04:00 PM
  #132
TXsilverado's Avatar
so when he first started tuning the truck it shifted out fine?
usually when my transmission starts slamming rev limiters i start saving for rebuilds. if it was in the tuning, charlie wouldnt have had a problem getting it to shift right. set the rev limiter higher and the shift point lower for starters...if it still slams its either a mechanical or maybe an electrical issue.
could have it possibly been the pcm itself? i just dont see a small issue like that making it past any tuner. ive had SEVERAL transmissions start slamming the 1/2 and 2/3 shift points. its usually not too long after that im having to pull the transmission. i dont think i have ever broken a hard part in the past 7 transmissions. im hell on clutches though haha.
quick SOFT shiftpoints are the key IMO. if your shifts feel like your being rear ended, your begging to scatter parts all over the track. unless im on a bad road, my truck rarely chirps 1-2 shift. not to say its not a firm shift but not slamming gears either.
time wise you will not see any difference with your line pressure jacked through the roof or every spacer installed on your shift kit.
Old Nov 1, 2009 | 04:57 PM
  #133
who built all these trannys????
Old Nov 1, 2009 | 06:26 PM
  #134
i was having them rebuilt under GM warranty
i was running mid 12's and low 13's on stock transmissions...they would last about 4 months per transmission and being rebuilt stock for free
life has been so much easier since gm refused another transmission and i swapped over to performabuilt.
Old Nov 1, 2009 | 07:54 PM
  #135
o well my tranny its built by the guy that built pacos 427........so he is a good builder his name is JUAN TRANSMISSION and pacos is a 427 with nitrous and on heavy *** 24s......so if you ask me he is a good transmission builder......
Old Nov 1, 2009 | 08:44 PM
  #136
Daryn's Avatar
Formerly darynC-10/23/10
u get **** dont quick, a few days ago i thought you were on a stock trans slipping and stuff
Old Nov 1, 2009 | 08:47 PM
  #137
it wasnt the tranny it was my tune....... didnt you read the other thread when i got my new tune????
Old Nov 1, 2009 | 08:54 PM
  #138
in the end, every transmission fails. god couldnt build a 60e to last forever. some just take more abuse than others. thats the best we can look for.
im sure paco isnt on his first transmission. ive heard great things about juan. ive also seen some of his transmissions go down. every builder has transmissions go down. theres no such thing as a invisible transmission. its part of "paying to play"
Old Nov 1, 2009 | 09:02 PM
  #139
thats true no lie.......
Old Nov 1, 2009 | 09:19 PM
  #140
gtosilverado's Avatar
yep, my cousin sammy broke some of his tranny's
