TIME SLIP DATABASE
Vmax 1/4 mile estimate (truck in signiture)
Old Apr 19, 2015 | 04:14 AM
Fast_six oh's Avatar
Originally Posted by Gypsy06vortecmax
no my 60ft sucked it was a 2.2 when the truck was bone stock it ran a 14.6
then maybe my goal of a low 14 is possible...
Old Apr 19, 2015 | 04:23 AM
Originally Posted by GMCtrk
You've got very good mods, but those tires aren't helping you.
Long before I was turbo'd, I went 13.7@99 on a stock LQ9, headers, 4.10s and my own tune. That was on 285/60/18 Toyo Proxes which were very large tires, 32" diameter. 60' was 2.0. You're pushing slightly more weight being 4wd and all, but with a good 60', I could see you hitting 14.0 maybe a hair under.
Well i bought some 265/70/17 tires today on some other gmc factory wheels so maybe that'll help some..may just press the 4wd button to solve the traction problem for now but im curious as to whether ill break anything or not...
As far as my mods go, i think they are pretty decent..i know there are better ones out there though...got told the other day that my blackbear 91+ scan cable tune was junk basically...i mean the truck runs strong for what it is...and the trans improvement was amazing..nice firm shifts and the shift points are so much better
Old Apr 19, 2015 | 06:13 PM
ZO6Ted's Avatar
You'll be fine with that little button . Plenty of trucks have gone 10's with stock 4wd setups. They are tough.
Old Apr 19, 2015 | 11:04 PM
We shall see..only other changes im thinking about doing is the exhaust..cam will come later on
Old May 14, 2015 | 02:28 AM
Headed to the track later this afternoon!! Ready to see what my new time will be!!
Old May 14, 2015 | 09:13 AM
Vortec350ss's Avatar
Thats awesome! What does the weather look like?
Old May 14, 2015 | 12:29 PM
75 degrees right now and its 12:30 in the afternoon..believe its gonna drop to the mid-low 60s tonight..humidity is down too
Old May 14, 2015 | 01:33 PM
thunder550's Avatar
High on diesel fumes
Run it in 4wd. There's no reason not to.
Also, not sure if you were brake stalling or just punching it when the light turned green, but definitely do the brake stall to help get you out of the hole.
Old May 14, 2015 | 02:38 PM
[QUOTE=thunder550;5290954]Run it in 4wd. There's no reason not to.
Also, not sure if you were brake stalling or just punching it when the light turned green, but definitely do the brake stall to help get you out of the hole.[/QUOTE
will be locked in 4wd for sure..and last time i was just rolling into it..i couldnt punch it last time because it would just knock the tires off in 2wd..Ill brake stall it as well this time
Old May 14, 2015 | 05:47 PM
10 Second Club
Sounds like decent weather, your tires are 1.5" shorter - will help the effective gearing. Looking forward to seeing the results.
