TIME SLIP DATABASE
Turbo 6.0 results
Old Aug 6, 2011 | 01:12 PM
slowlsx's Avatar
Default Turbo 6.0 results
Well I want to see what u guys think. Took my truck to the track on 15 psi and made one pass, I'm here in Houston Texas and I was sweating just standing there. Nobody was getting timeslips but friends and family saw the pass. Left at idle and ran 12.2 at 115 with iats of 188* and 7-10* total timing down the whole track and was shifting right at 6100!
Should I be happy with those results? If I had my full 15* of timing how much mph would I have ended up with?
I can say when I left my iat's were 99* and I ran my dads Camaro that traps 121 and I pulled away from him like was standing still amd my iats never went over 135
Truck is a lq4 stock heads 232/240 and t-6 s476
Old Aug 6, 2011 | 01:40 PM
Beatdown Z's Avatar
Laid Back
Under those circumstances, you should be satisfied with your results, imo.
Old Aug 6, 2011 | 03:19 PM
TIM Z's Avatar
11 sec. Truck Mod
In that heat *** yeah your doin good !
115mph thats fast!!!!!!!!!!!
Old Aug 6, 2011 | 03:35 PM
slowlsx's Avatar
Yea 115 is decent but I want 125-127, maybe I can do that with all my timing and raise shift points from 6100 to 6500
Old Aug 6, 2011 | 03:58 PM
smokeshow's Avatar
Mod with training wheels
I think your goals are pretty reasonable if you get that timing up. I thought you said your IAT was 188?
Old Aug 6, 2011 | 04:18 PM
slowlsx's Avatar
They were... It sais it at the top lol! My iats were 99* cruising home
Old Aug 6, 2011 | 05:00 PM
schino's Avatar
but then you said this
im guessing that was on your way home? good runs none the less in the heat
Old Aug 6, 2011 | 05:29 PM
stock48's Avatar
9 Second Truck Club
Should be doable. Last night I went 129.32 mph on 13~14 psi in my mph robbing 4x4. Lq4, Isky 212 cam, shifting at 5500. T78 with the little 68mm exh wheel. 17* of timing.
Old Aug 6, 2011 | 05:58 PM
slowlsx's Avatar
Yea that was on the way home.
U think it's worth pulling my lower valence since my intercooler is right behind it, pull my big KNN filter off my turbo and pull the headlight out?? Gonna go tomorrow and make a few passes 1/8 around 7-8pm since it's alot less humid at those times.
Old Aug 6, 2011 | 06:03 PM
stock48's Avatar
9 Second Truck Club
Yes and also mist the I/c with a little water between rounds, just mash the brakes a couple times before you run so it doesn't drip.
