TIME SLIP DATABASE
turbo 4.8 11.21 pass
Old Jul 25, 2014 | 05:03 PM
  #21
black4.8's Avatar
Are your 60' limited by traction or low end torque?
its all about the power/tq. traction has always been great. leaving on 8# boost, just really rich holding power back
Old Jul 25, 2014 | 06:48 PM
  #22
fastjweb's Avatar
I bet some lower gears would help you out, Im going to try some 3.90s I think.
Old Jul 25, 2014 | 09:49 PM
  #23
black4.8's Avatar
I can't w/28" tire. crossing traps at 6300rpm now. that's right at max power on dyno.
Old Jul 26, 2014 | 05:38 AM
  #24
JoeyGC5's Avatar
I've got the same off the line issue as you. I'm in the middle of going from 3.42s to 4.10s in my 14 bolt to get my pig off the line better. I run 28" M&H's and hopefully will be crossing the line around 65-6600. If a little higher I'm not worried.
Old Jul 26, 2014 | 10:03 AM
  #25
BigKID's Avatar
You may want to look at your converter as that seems like a lot of slip. With 3.42 gears, directly coupled, 123mph should be around 5Krpm and 6300rpm should be around 153mph. That's a 20% slip at the traps.
Old Jul 26, 2014 | 07:38 PM
  #26
black4.8's Avatar
I've calculated the converter slip also and I know 15-20% is on the high side even for th400. probably pushing converter pretty hard, only rated for 800hp. tranny temps never over 190 though. i'll wait til 4.8 lets go and get a better converter.
Zizzle
Oct 19, 2017 08:44 PM
03regcab sierra
20
Aug 3, 2015 12:11 AM
GMCtrk
Jul 17, 2015 06:39 PM
Cowboy17
Jul 9, 2015 08:22 PM
