TIME SLIP DATABASE
transbrake button mounting locations
Old 12-19-2014, 11:56 PM
SumtinCoo's Avatar
Default transbrake button mounting locations
Where are you guys with tbrakes mounting the buttons in the cab? I've got a 01 and I'm building a 80e with a d3 brake. I've already got a nx switch panel for the 4wd cubbie hole and it's full with nitrous arm, tbrake arm, line lock, and purge. I'd like to put it on the steering wheel but all I can find are push to talk buttons and I'm not sure if I want to risk accidently hitting the button while going down track. Thanks and show me some pics of what you got.
Old 12-22-2014, 10:17 AM
SumtinCoo's Avatar
No one running a transbrake?
Old 12-22-2014, 01:41 PM
I have a gauge for that
Atomic's Avatar
Ive seen one attached to the shifter arm...
Old 12-22-2014, 02:02 PM
SumtinCoo's Avatar
Well I'll be using a b&m quicksilver in the console so no go on the shifter haha
Old 12-22-2014, 02:15 PM
sprayedenali's Avatar
I had the D1 brake and had it mounted on the shifter since i already had my hand on it.. now i have the D3 one and not sure where ill put it. i might end up with an aftermarket steering wheel and put the linelock and t brake buttons on it
Old 12-22-2014, 03:24 PM
SumtinCoo's Avatar
Yeah I've been thinking about that but I'd like to keep my stock wheel until I have to put a cage in it which shouldn't be that long anyways.
Old 12-24-2014, 02:13 AM
8 Second Truck Club
Blown06's Avatar
I use the button on my ppp shifter. Probably gonna move it to the wheel though.
Old 12-25-2014, 05:02 AM
mdwatts11's Avatar
Not sure what year truck you have but if it's a 4 speed you could get a newer 6spd shift lever and use one if the manual gear select buttons (+ or -).
Old 12-26-2014, 12:19 AM
SumtinCoo's Avatar
Well the truck was a t56 swap and I ripped out all the column **** and the shifter cable so I'm going to get a console shifter to make it easier and it would look better imo. This is what I was talking about for on the stock wheel. I just don't know if I'd hit it or not accidently. HD Coil Cord Velcro PTT for Car Harnesses, 502 & 510 Intercoms [PTT-VM2] - $50.00 : Rugged Radios: Headsets, Intercoms, 2-Way Racing Radios and Communication for Motorcycles, Offroad, Circle Track, Aviation, Drag Racing, NASCAR, Police, and more...
Old 01-05-2015, 11:31 PM
Ph.D. in HUBRIS
custm2500's Avatar
I use the horn for my line lock, but I don't know it would work well for the trans brake. Light pressure with my thumbs and hold the two bottom spokes of the wheel.
Csnell3732 (03-06-2017)
Quick Reply: transbrake button mounting locations
