track problems
There is an issue right there! You added 3 inches of tire to your ride. You probably get a hard spin on the shift, which holds boost on the street. Also the taller tire adds mass and takes away gear. You need a trans tune for the taller tire too. Try a 26X10X16 tire and you may be much happier.
a friend of mine had the same setup , same stall and would pick up 10lbs right from the start, so theirs defendantly some thing wrong
