TIME SLIP DATABASE
Tested out the TR220...AGAIN!! NEED HELP!!
Old May 31, 2007 | 06:26 PM
BlackPearlZ71's Avatar
Originally Posted by 99Silverado5.3
You made zero changes from last time, correct?
yup zero changes
Old May 31, 2007 | 06:27 PM
Originally Posted by ChevyThunder17
Did you drive it like you stole it on your way out to the track? The GM VCM seems to respond better when you beat the hell out of it (and I'm not sure why). My Camaro SS on the dyno went from 315 on the first pull to 327 on the third pull.
Could be your tire pressure too...
u know wut man, i completely forgot about lowering my tire pressure.
Old May 31, 2007 | 10:20 PM
ZO6Ted's Avatar
I've not been able to hook at all before with different vehicles and had a higher trap with a slower ET than a previous run. I just figured that I was up in the power band and made more average horsepower for that specific run.
Old Jun 1, 2007 | 10:53 AM
Cuerva's Avatar
11 Second Truck Club
Tire pressure is not it. Truck was hooking fine, even when I ran it. There's something with your 60's. Mph is there, if feels good after the takeoff but not coming off the line. Last July mine was hitting 13.2's with 1.84/1.83 60's at 100mph and no pulley, so from high 1.8's to low 1.8's there's another 10th for you. Just my 2 cents. Overall, truck's running up to par. Just have to find the sweet spot on the lauch.
Old Jun 1, 2007 | 11:02 AM
David Avila's Avatar
Totally agree with La Cuerva on this one.
Old Jun 2, 2007 | 09:49 AM
litreddevil's Avatar
Banned
i know if you spin off the line you will run more mhp,than if you dry hook with the same day same truck.
on a dry hook run with you not holding nothing back on the starting line you will run faster et and slower mhp if you spin just a little your et will drop and the mhp will go up.
i was told by other older racers that it is due to when you spin then hook up the motor is in a different power band (different rpm range) and most of the time it will be in a higher rpm so you cross at a higher rpm.
hope this helps
Old Jun 2, 2007 | 04:11 PM
chapita's Avatar
just wait till winter, i myself had the same problem
Old Jun 2, 2007 | 05:15 PM
v8
17,16,15,14,13,12,11 Drvr
in the best DA and the worst DA i've ran the same mph, mph is your hp rating, now with better or worse DA it will change your times.
like this 89*104mph
...........59*104mph
Old Jun 3, 2007 | 12:39 AM
hope this helps
well i know my 60ft was shitty, but surprisingly i was hooking pretty good...i guess i'll just wait till i install my TruTrac in the next couple weeks and see how i do then.
Avalanche2002
Nov 30, 2015 07:31 AM
Tydriver
45
Oct 23, 2015 09:19 PM
BlownHD
Oct 3, 2015 12:24 PM
jfuegner
Sep 22, 2015 12:30 PM
RONIN LSX
Sep 15, 2015 12:57 PM
