TIME SLIP DATABASE
Regular cab drag setup questions
Old Jan 24, 2012 | 01:20 PM
  #31
slowec's Avatar
Dang, I have the overload removed and 2.5" drop shackles and yours is lower... UGGG!!!
Old Jan 27, 2012 | 06:54 AM
  #32
slowec's Avatar
Am I the only one who ever wanted info on some drag shocks on here or is everyone just not wanting to share what they found that worked???
Old Jan 27, 2012 | 08:35 AM
  #33
JoeyGC5's Avatar
IMO can't go wrong with QA1's and custom mounts
Old Jan 27, 2012 | 09:04 AM
  #34
KDavis04ss's Avatar
Rodney you looking for front and backs or just backs. Speed engineering sells bolt in QA1's but they are for a 4/6 drop. If you do go lower in the back i imagine you would drop the front also so they will work. They are also 12 way adjustable
http://speed-eng.com/store/suspensio...3_75_3702.html
Old Jan 27, 2012 | 09:28 AM
  #35
BigKID's Avatar
I've got QA1 single adjustable front and rear on my truck. Don't know the part numbers off the top of my head though. I had to build some spacers for the front to keep them from bottoming out on compression but they still arn't quite long enough for full extension of the suspension. One of the fronts has been leaking for a while and I believe it is completely dead now so it will have to be rebuilt. Like someone said earlier, take some suspension measurements on your truck then look thru the AFCO, QA1, Rancho, Koni, Strange and VariShock catalogs to find one that works with your suspension travel.
Old Jan 27, 2012 | 01:32 PM
  #36
JankesGTO's Avatar
QA1 Shocks / Speed Engineering Performance Parts - LS1, LS2, LS3, LS6, LS7, LSX, LT1, Camaro Parts, Corvette Parts, GTO Parts
I wish I would have known about these before I ordered from caltrac...
Old Jan 27, 2012 | 11:20 PM
  #37
Blown06's Avatar
8 Second Truck Club
Those qa1's don't actually fit very well as a "bolt on"
Old Jan 28, 2012 | 06:32 AM
  #38
foose04's Avatar
The front or rear?
Old Jan 29, 2012 | 12:36 AM
  #39
Blown06's Avatar
8 Second Truck Club
The front.
If you call speed engineering they should tell you that a customer of theirs "told them" that the 1576P's would bolt right up, so thats why they put them on the website like that. Truth is, they won't even work with a stock spring and need to be modified if using a 2" drop spring. Also, they don't come with the correct lower T, or the correct upper bushing.
Old Jan 30, 2012 | 08:07 AM
  #40
slowec's Avatar
And they are 320.00 for the front and t bolt kit...
