TIME SLIP DATABASE
Regular cab drag setup questions
Old Aug 3, 2011 | 07:37 AM
slowec's Avatar
Default Regular cab drag setup questions
My truck has 2000 model everything except 2" shackles and spring clamps.
1. How much drop would adding v6 front springs give me? Good idea or not?
2. Thinking about summit sum g7600 adj shocks. good start???
*caltracs out of the budget for now*
Old Aug 3, 2011 | 08:33 AM
00buckshot's Avatar
Build you some bars! you can build them for under 100 bucks if you can get a good deal on steel! hell even some universal traction bars would help you for now
Old Aug 3, 2011 | 08:36 AM
low2001gmc's Avatar
Check out urdone's thread on lakewood shocks on the gm drivetrain/suspension section.
Old Aug 3, 2011 | 02:52 PM
slowec's Avatar
325/50/15 hoosier drag radials will be used.
Old Aug 3, 2011 | 03:03 PM
chevrolet all the way's Avatar
i had nothing but shackles, monroe 11.99 shocks, and mt et streets 28x10.5x16 and cut consistent 1.6 60ft and couple of 1.5s. that was a 4.8 spraying 150 out of the hole.
just make sure you have good tires that are warm with the right air pressure.
Old Aug 3, 2011 | 05:16 PM
quicksilverado's Avatar
X2 All I have is good tires at the track 1.5x 60ft.
Old Aug 3, 2011 | 05:45 PM
slowec's Avatar
The Hoosier drag radial came today. They are fresh, huge, and sticky. I have considered fabbing some long bars or adding some 90/10 front shocks.
You 1.5 60 ft guys make sure to come to the shootout in Nov. and show me how its done.
Old Aug 4, 2011 | 06:08 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
i had my v6 springs in my truck and it did not drop much at all if ANY... a 4.3l has iron heads so the weight is not much different from the v8
this is V6 springs with 408ci and a t6 turbo kit (turbo 57lb) and th400 installed
Old Aug 5, 2011 | 05:01 AM
slowec's Avatar
If they stand that tall , I guess they won't provide the compressed pressure to help lift the front end on a drag launch like I am looking for.
Looking to build a CHEAP drag setup...
Old Aug 5, 2011 | 07:26 AM
00buckshot's Avatar
You cheapo, some things you just cant skimp on bro, just have to spend that money!
