TIME SLIP DATABASE
Pitt 402 Launch pic 7 dyno
Old Jan 14, 2009 | 02:45 PM
  #21
vanillagorilla's Avatar
I can't get over how hard KP's parallel 4 link launches. I'm interested to see how much you can get that 60ft down with that setup.
Old Jan 14, 2009 | 02:58 PM
  #22
pittman's Avatar
I was supprised myself. My son Sport Side set it up (post #17). Maybe he will get back on and say what he did. I know he lowered it by changing the springs and added the QA1 shocks. We also took the bed off and I adjusted the bars exact with the axle square to the frame. It was about a half inch out of wack.
How about it Sport Side...cough it up for the boys !!! What springs did you put on this thing ???
Pitt
Old Jan 14, 2009 | 03:19 PM
  #23
rgvsierra's Avatar
if you really can get down to a 11.1/2 that would be awesome. i'm stuck in the 11.5 range (11.49 best) but i'm in process of swapping cam/headers. 11.2 would be the point where i'd stop and then start test and tuning with n20.
i imagine spray is next on your list? what do you have lined up for that? direct port?
Old Jan 14, 2009 | 04:29 PM
  #24
pittman's Avatar
My son, Sport Side in post #17 has a dry shot kit he ran on the old setup. I presume he still has bottle and blanket as well.
Just got in the skinny's. 4" steel Rim weighs close to 21 lbs and the tires 16.5 lbs. That is a savings of 20 lbs per wheel plus a 2/3 less friction from tire width.
I'm gonna change to the skinny's, pull the front bumper, sway bar and add the 12" slicks. Add in some cold air and it should Rock !!
I figure about 220-250 lb weight loss off the nose if you add the alu block to the formula.
Pitt
Old Jan 15, 2009 | 12:56 PM
  #25
litreddevil's Avatar
Banned
Pitt
pic of the rims you are going to take the whole bumper off
Old Jan 15, 2009 | 06:11 PM
  #26
pittman's Avatar
Just got the skinny's mounted. The rims required a little grinding on the calipers. Not much though. Waiting on the slickes to arrive tomorrow. If they don't come I may have to hit Valdosta next Saturday.
Front bumper and sway bar are off.
Pitt
Old Jan 15, 2009 | 08:44 PM
  #27
pittman's Avatar
Here is a pic of the 10" rim for my slicks that Fed-x has lost !!!
The tracking number says they were left on my doorstep...one this morning and one at 5:30pm (now that is planning). No truck came down this raod. They are trying to locate them now !!
Old Jan 15, 2009 | 09:54 PM
  #28
getonit's Avatar
Good luck and congrats on a bad *** setup!!!!!!!!!!
Old Jan 16, 2009 | 06:33 AM
  #29
pittman's Avatar
Thx, gonna run tomorrow with or with out slicks !
Old Jan 16, 2009 | 01:29 PM
  #30
pittman's Avatar
I GOT RUBBER !!!
Pitt
