TIME SLIP DATABASE
New world record sbe 4.8!
Old Oct 10, 2016 | 12:37 AM
  #21
Blown06's Avatar
8 Second Truck Club
And your engine feels like it's making far more than 100 more... what is your drive loss from the blower? 150? More? That means the cylinders feel like they're makin way more power... that's where a turbo becomes hugely beneficial at these power levels.
Great run!
According to the testing that Morris has done, the F2 at the blower speed I was running.......it soaks up 250 hp. So if I was getting a true 1100 through the flywheel, the bottom end and head gaskets where feeling 1350 or so.
Old Oct 10, 2016 | 07:59 AM
  #22
03regcab sierra's Avatar
That's robbing quite a bit of power but hey it pushes your truck to an 8 second pass so it's impressive none the less.
I'm calculating the truck to be about 1100 flywheel hp. Having a 4l80e trans and a 14 bolt rear axle it's robbing a lot of power as well.
Going back to test this Friday. If we can put the power to the ground I'm hoping to run a little better than last time out.
Old Oct 10, 2016 | 10:22 AM
  #23
03sierraslt's Avatar
Believe it or not the 80e doesn't rob hardly any more then a 60e. The mechanical advantage in lower gears is different due to the ratios but in a true 3rd 1-1 pull they are similar.
LOBO2
Dec 15, 2020 08:00 PM
CK@UPP
Sep 28, 2016 06:56 PM
Silverado256
Sep 4, 2016 10:49 PM
2ToNe04
Aug 28, 2016 01:36 PM
lxcoupe
Aug 19, 2016 04:57 PM
