TIME SLIP DATABASE
new times....help
Old Mar 9, 2009 | 09:14 PM
Silverad04's Avatar
Default new times....help
So I went to the track thinking I would have no problems running 13s with the new blower. My time with lt's tune, efans, x-pipe, and cai was 14.7. I only dropped seven tenths. Could it be the tunning? I had Wheatley tune my pcm(mail order) I know I need to get a dyno tune, but shouldn't it be running better then this? check out them bad azz reaction times....LOL
Here's my times with all above listed mods and an intercooled Radix with 3.4 pulley
r/t-----------.8629
60------------2.3010 what about this nasty 60?
330-----------6.0469
1/8 et---------9.1061
1/8 mph-------79.94
1/4 et---------14.06
1/4 mph-------98.93
r/t-----------1.2099
60------------2.2991
330-----------6.0651
1/8 et---------9.1301
1/8 mph-------80.05
1/4 et---------14.0799
1/4 mph-------97.83
r/t-----------.7928
60------------2.2121
330-----------6.0102
1/8 et---------9.1462
1/8 mph-------78.12
1/4 et---------14.2243
1/4 mph-------96.79
r/t-----------1.2299
60------------2.3301
330-----------6.1020
1/8 et---------9.1781
1/8 mph-------79.91
1/4 et---------14.14
1/4 mph-------97.26
Old Mar 9, 2009 | 09:39 PM
quicksilverado's Avatar
You have the mph for 13s. You need to get your 60" time down.
Old Mar 9, 2009 | 09:40 PM
regency's Avatar
a stall would help you soo much!!
Old Mar 9, 2009 | 09:42 PM
sureshot's Avatar
Yeah man, you definitely have the speed for 13's, just get those 60's down and you'll be there.
Old Mar 9, 2009 | 09:47 PM
regency's Avatar
looking more at the times!! It looks to me that he is spinning pretty bad!
Old Mar 9, 2009 | 10:01 PM
sixltrbtr's Avatar
Are you running slicks or street tires?
Old Mar 10, 2009 | 05:31 AM
Silverad04's Avatar
I am running the stock tires on my heavy azz 80 lbs sss rims.
Old Mar 10, 2009 | 06:15 AM
dirt track racer 81's Avatar
you need a better 60 and youll be in the 13s easy
Old Mar 10, 2009 | 08:12 AM
krambo's Avatar
What gears do you have? I am assuming you are 2wd? With the tall 20" SSS rims and tires you swapped and a numarically low rear, your final gear ratio most likely is not suited for getting out of the hole. Add tire spin and it is most likely a mutt on the launch. A light, short (< 29" tall) and sticky wheel/tire combo will most likely get you several tenths...hell, I'll venture to guess a half second or better.
Old Mar 10, 2009 | 10:22 AM
Silverad04's Avatar
I have 3.73 gears and I am 2wd. So is 29" tire best suited for my combo? I will have to get some drag radials. Also I was planning on getting an flt 65e with a tt2600 down the road. Or should I go high on the stall?
