New times on the 427 +vid
10 Second Truck Club
Made a few passes today trying out a 100 shot. The vid is an in truck showing what happened when I hit the shot off the line. It blowed the M/t's off and shifted to second. The next pass I waited till second to hit the spray but forgot to turn the camera on! It went 1.55 60', 6.79 1/8th, 10.69 @ 125.14 thru the 1/4. I believe if I can tweak the suspension alittle more or maybe go to an all out drag slick low 10's and 1.4x 60's are possible. By the way it was lifting the front wheels 3-4"!
Still full weight (except spare)and thru the mufflers.
frt suspension is way too loose for my taste IMO. good loose lift but not stiff enough compression imo. sick times! 28X10 hooser slicks on a 10" wide wheel should plant that beast with your suspension setup
off subject but what pinion angle are you runnin?
