TIME SLIP DATABASE
New PB 9.47 at 141
Old Apr 6, 2020 | 06:25 PM
Slowtrap's Avatar
that is awesome 60' off the footbrake. what #s it putting down. got an iron block and regular bed on mine but that is the mph i would like to be at. mine ran 105 in 8th @ 700 rw,now it's 900 but not got to hit the track . congrats
Old Apr 8, 2020 | 02:32 PM
99ta's Avatar
What meth kit, what size nozzles? Any other details?
Old Apr 17, 2020 | 09:52 AM
fastjweb's Avatar
Should be around 875 tire. I dynode it at 23lbs and it made 876/906. These runs on about 21-22lbs but mph and weight estimate it about 875.
Old Apr 17, 2020 | 09:59 AM
fastjweb's Avatar
Snow kit, dual 625ML nozzles, about 9.9 gph each. Have them coming in at 9lbs and full spray by 11lbs. L33 5.3, cam,springs,head studs. TBSS intake with the 78MM TB (used ICT adapter) stock TBSS rails, added a -6 reg using quick connect fittings to stock feed and return lines to tank, 450 and 255 in tank, both on hot wire kits, 255 on 7lb hobbs switch. Trick T4 kit, upgraded to the 4" race intercooler, using a T4 t o T6 adapter to run the VS billet 80.
fastjweb
Aug 1, 2023 05:32 AM
fastjweb
Oct 7, 2019 09:22 AM
fastjweb
Mar 24, 2019 11:00 AM
2005 Silverado
Aug 17, 2012 09:31 PM
stock48
May 4, 2008 05:41 PM
