New PB 9.47 at 141
that is awesome 60' off the footbrake. what #s it putting down. got an iron block and regular bed on mine but that is the mph i would like to be at. mine ran 105 in 8th @ 700 rw,now it's 900 but not got to hit the track . congrats
Snow kit, dual 625ML nozzles, about 9.9 gph each. Have them coming in at 9lbs and full spray by 11lbs. L33 5.3, cam,springs,head studs. TBSS intake with the 78MM TB (used ICT adapter) stock TBSS rails, added a -6 reg using quick connect fittings to stock feed and return lines to tank, 450 and 255 in tank, both on hot wire kits, 255 on 7lb hobbs switch. Trick T4 kit, upgraded to the 4" race intercooler, using a T4 t o T6 adapter to run the VS billet 80.
