New PB! 6.39@107
Only ran twice tonight...still having issues with the knock sensors going off. Still spraying meth and I put 10gallons of e85 in the tank before going to the track and it still wants to pull timing. Pulled 5-6 degrees (max allowed is 6) most of the first run and trapped 103. Plugs looked fine so I went out on a limb and set the max retard to 2 degrees and trapped 107...plugs still look good afterward so im pretty sure something is just banging around giving me issues. This track is known to trap a few mph slower than normal.
Best run I left on the 2step at 4000...I think the sweet spot might be around 3600-3800, but still managed to launch on 18psi after a burnout and got mitch to clean off my front tires
Thanks mitch!
It still pulled 2 degrees most of the run (total timing around 13 degrees). Injectors were around 102-105% most of the time, so im glad I have meth to spray on top, and this is at a 0.80 lambda. I may try a higher base pressure (70psi perhaps) to extend these a little further. Curious to see how the denso pumps like the higher pressure... I also clearly need to get stiffer rear shocks...might try to fab something up for that this weekend too...
New cam goes in this weekend
Heres another vid from the side a friend took with his phone
http://www.youtube.com/watch?v=Ekbew...ature=youtu.be
I watched a video of the first run I made in slow motion. I spun all 4 through first gear and the front tires were definitely dancing toe in the whole time. Pretty sketchy
