TIME SLIP DATABASE
new PB on 20s
Old Nov 23, 2011 | 09:23 PM
iamkeniff's Avatar
Default new PB on 20s
Full weight, 20" wheels, jack, breaker bar, full tank of gas
1st pass:
13.31 @ 107.68
2.078 60'
2nd pass:
Spun out the hole bad!
13.33 @ 107.9 2.13 60'
3rd pass:
New PB!!!
13.29 @ 105.11
2.03 60'
Time for some tires and a converter
Old Nov 23, 2011 | 09:31 PM
AJII's Avatar
You'll soon have a 12 sec bus!
Old Nov 23, 2011 | 09:51 PM
iamkeniff's Avatar
Again
Old Nov 23, 2011 | 11:22 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
What made you decide to go with a converter again? With some stickies and even a mild converter you should be well into the 12s. Not bad for a non stripped down tank. Any plans for a different cam like you talked about a while back? Congrats on the times.
Old Nov 24, 2011 | 12:51 AM
GMCSIERRA5.3's Avatar
Mods?
Old Nov 24, 2011 | 05:36 AM
iamkeniff's Avatar
E.T wise a smaller cam would do better, but why fight trying to sell the cam and then have to redyno the truck and just waste money on that? a converter is mainly for the brakes, with this cam and tight converter the truck is trying to push through the converter. it gets pretty annoying in stop in go traffic. on DRs i know i have a 12.8-12.9 pass but id like to see how it'd run on a 10.5" 3200 converter. i also want to upgrade the flexplate again, with so many stock ones breaking im a little nervous with this one.
Old Nov 24, 2011 | 05:37 AM
mhotrodscooter's Avatar
Where the hell did that 107.9mph come from?
Anyways congrats on the new times. I wanna rematch..
Old Nov 24, 2011 | 05:39 AM
iamkeniff's Avatar
Originally Posted by GMCSIERRA5.3
Mods?
6.2/6L80e/tru-trac/4:10s
228/236 112+4
EPS dyno tune/Truckshop tune/Area47 Adjustments on the trans
Decked stock port heads (.020")
Pacesetter LTs/pos Y pipe, 36" Magnaflow muffler
UD crank pulley
90mm TB
4" CAI
Stock converter
on my old setup (6.2/4L60e/3600 9.5" converter, also had 28" DRs) it went 12.73 @ 105.5 pausing on the shifts
Old Nov 24, 2011 | 05:42 AM
iamkeniff's Avatar
i dunno where it came from but it was back to back with shitty 60's
thats fine, i didnt change anything other than the way the transmission shifts. Area47 and I put the TM back in it and adjusted from there. i love the way the truck shifts at part throttle no more neck breaking shifts and spinning the tires on the shifts!
lets rematch anytime you want! i'll never E.T what you run but thats ok...ill pick you up on the street
Old Nov 24, 2011 | 06:30 AM
Must of had some really good DA on the first two passes.
I'm sure with a converter & tires it would be a good heads up drag races. as long as you don't get caught sleeping at the light.
