TIME SLIP DATABASE
New PB 10.2 at 124
Old Aug 28, 2018 | 11:17 AM
  #21
fastjweb's Avatar
Originally Posted by milesp07
How does this setup drive on the street compared to the 4.8 with the sxe369? Is it still as responsive?
it is no where near as responsive as 4.8/369 combo. It is not terrible lag, but other set up was all in much quicker. A good example, 4.8/369 on 2 step at 3500 rpm, you could start building boost when first bulb dropped and hit 8lbs by the time 3rd bulb lit, launch at 8-9lbs, gates would open at 15-18lbs while you were still passing the tree. 5.3/75mm big turbine and 1.32 AR, took 4.5 seconds to build 6lbs on 3700 2 step, gates open at 15 psi 60-100 feet out. Both combos on same boost level, 4.8 had 3 more degrees of timing. 4.8 went 1.50 60ft 6.61 at 104.3 in -750-1000ft DA, 5.3 1.52 60ft 6.52 at 106.5 in +1000ft. 4.8/369 was quick for what it was.
Old Aug 28, 2018 | 10:57 PM
  #22
lycominghunter's Avatar
Yeehawwww!
Old Aug 29, 2018 | 03:13 PM
  #23
milesp07's Avatar
Thanks for the info, sounds like a pretty significant difference. How about on the street? If you don’t brake boost it from a stop, how long does it take to get into boost? How was that with the 4.8 s369 combo?
Old Aug 29, 2018 | 08:19 PM
  #24
fastjweb's Avatar
4.8/369 would destroy tires from stop. This combo gets out aways then takes off. Both combos killed tires from 60 roll on radials if brake boosted a little.
Old Aug 30, 2018 | 12:09 PM
  #25
ZO6Ted's Avatar
Really appreciate all the details!
Old Aug 31, 2018 | 01:26 PM
  #26
milesp07's Avatar
that’s crazy to hear. Mine is quite the opposite. IF I don’t brake boost it, it’s takes 3-4 seconds before it builds any... then it takes off like you would expect. I have a 3200 stall as well. I’ve been thinking of swapping the 4.8 for a l33. Thanks for all the info on your build, it’s been fun watching your progress! Sounds like 9s are in your near future!
Go5.3tt06
May 4, 2017 02:20 AM
thewrx
Oct 6, 2015 10:59 AM
JJ_TURBO
Apr 26, 2008 12:50 AM
TrickTurbo
Jan 23, 2008 11:37 AM
Toe
Oct 27, 2004 05:19 PM
