New best time...6.45 1/8th w/1.43 60ft.
10 Second Truck Club
I actually have 2 systems. The primary is a ZEX kit with fogger nozzle and 125 hp jets. It is programmed to activate at WOT. Also retards timing up to 10* when activated. The second system is a CompCar with fogger nozzle and 100 hp jets. I have it on a button and retards timing when activated also. Have not used both of them together yet but will when the right situation comes up. I have a 15lb NOS high flow bottle and all 6an lines.
What QA1's are you running in the rear? What setting did you wind up putting them on? How do you have the cal-tracs set? I've been reading that you should set them up with a nickel's worth of clearance between the contact bolt and the leaf. I'm not sure if this works on trucks though.
9 Second Truck Club
Nice times! You should have easy 9's there when you hit that 2nd shot, maybe even with the 1st shot if you can get into it 10' sooner. I just watched your videos, can't believe I didn't come across them before. That looks like a neat track with all the trees. It will be interesting how long that 4L60 holds into the 9's
What is your race weight? Is that a vette 427 worked over or is it a LSX build up?
