TIME SLIP DATABASE
New 8 and 10 speed trannys
Old Sep 22, 2018 | 02:42 PM
pittman's Avatar
Default New 8 and 10 speed trannys
Has anyone installed one of these in their 1999 to 2004 trucks ? Does it require an aftermarket computer?
I went to Holley Fest and my truck ran a couple 12.0 to 12.10. I thought it was the heat, but when i looked at the log it shifted at 3500 and 5200 rpm. Ran like a dog. I need a trans controller !!!
thx
pitt
Old Sep 22, 2018 | 02:44 PM
pittman's Avatar
Same issues i had with old tranny
definately an electronic issue. I tried swapping computer's and same thing for 3 years now.
Old Sep 22, 2018 | 03:11 PM
pittman's Avatar
I have an xtra 4l60e for sale.
i thought it was messed up but new performa built did the same thing.
Old Sep 22, 2018 | 03:35 PM
03sierraslt's Avatar
What trans do you have?
Old Sep 22, 2018 | 05:28 PM
FFDP's Avatar
As far as I know it's basically impossible to control a 8 speed or 10 speed computer without the factory computer and various other modules . The transmission is setup specifically to run on those torque based computers.
Old Sep 23, 2018 | 02:34 PM
pittman's Avatar
factory 4l60e built by 30 yr trans builder in Middleburg FL. He built trannys for Hardcore on here running his yellow GTO
Thx for info
Old Sep 25, 2018 | 11:30 PM
brandon6.0's Avatar
There's 1 or 2 companies tht supposedly make a stand alone controller for the 6l80e. Cant think of them currently.
I do alot of ls swaps and i only use the 6 speeds with a engine/wiring setup thts 2007+ they need a e38 ecu and work off of canbus. These setups also need canbus interface gauges to work correctly.
I wouldnt even want to attempt to install one in an older platform. They are a lil tricky to tune as well. Way more tables than a 60/80e.
For your setup i would go 4l80e or th400. They will last, and hold up to what ever u put to them. I dont even bother with the 4l60e trans anymore. They never hold up and cost more than they are worth.
Old Sep 26, 2018 | 02:03 PM
pittman's Avatar
Thanks for info. This will probably be my last 60e.
I just ordered the US Shift controller. I contacted Performa Built and they also recommended that controller. We shall see how it goes.
Old Sep 26, 2018 | 09:28 PM
1FastBrick's Avatar
Custm2500's Rude Friend
PCS makes a stand alone controller and harness for the 6L80E/6L90E
TCM2650 MECHATRONIC TRANSMISSION CONTROLLER
Old Sep 27, 2018 | 06:34 AM
pittman's Avatar
i read about that one too. Not a bad unit
