TIME SLIP DATABASE
Launching a Magnacharger...
Old Mar 6, 2009 | 10:05 PM
brobradh77's Avatar
Trial and error from myself and others that run a maggie shows from idle or around 1800 gives you the hardest launch. Radix has so much low end torque you acttually sart taking it out of the power curve at 2600 or so.
Old Mar 7, 2009 | 12:01 AM
03tahoe22's Avatar
I was only planing on a couple runs this setup has me scared it is going to blow... I feel alot more comfortable with just the supercharger... guess I am going to have to test it. Sticky drag radials I dont see doing much better than 1.8 or is 1.6 possible?
Old Mar 7, 2009 | 02:15 PM
Ross @ EDO's Avatar
FormerVendor
Your just gonna have to see what works best, in my old LQ9 powered 02 rcsb with a 3800 verter I did better by flashing it, in my current Z28 with a 3800 it does better brake stalling it.
Old Mar 7, 2009 | 03:45 PM
BigCountryx's Avatar
My Magnafied LQ4 in my HD had the stock 80E converter and I could roll hard into it off idle and keep it straight, but would blow the tires off if I tried to stall it at all. Every setup reacts differently.
Old Mar 8, 2009 | 03:26 PM
GoatChs's Avatar
I'm not familiar with the curve of a Radix on a stock engine, but I did not see the curve drop on either of my setups until 4500-5000.
After you brake stalled it, did you punch it or roll into it? Or try both and still lost traction?
I cannot see how we could keep traction any time we punch at the line...
Old Mar 9, 2009 | 10:59 AM
BigTex's Avatar
My AWD Silverado SS with Radix and 2800 converter cut a 1.6x 60'. I would brake stall it up as high as I could without overpowering the brakes (maybe 2400 rpms), then on the light, I would floor the throttle first then release the brake a half second later.
Old Mar 9, 2009 | 11:40 AM
dewmanshu's Avatar
Moderately Differentiated
LOL I cut my best 60' when I finally stopped doing it that way. Stalling it up always netted me slower 60's (1.78 to 1.88).
I got the rpm to ~1250 and smashed it on last yellow. BINGO for me. I remember when KySilverado was up here, he was having lots of success launching his 4wd radix the way you do. My set up just didn't like it.
Old Mar 9, 2009 | 12:29 PM
krambo's Avatar
That is what gave me the best 60ft and E.T. If I floored it at idle, I would get a tick of KR and high 1.6x, power braking to 2K gave me 1.7's with no KR. I settled on a 1000rpm power brake and them mash it. Many times I would be a bit sideways till the DR's bit.
You will need to experiment as obviously each set-up is different.
Old Mar 10, 2009 | 09:59 AM
BigKID's Avatar
Personally, I like to flash the converter, i.e. ~12-1500 stall then mash it, when traction allows with previous setups. However, with my current setup it blows the 28x10x16 Hoosiers off leaving at anything over idle and agressively rolling into the throttle.
Like it has already been said... every setup is different and is going to take some trial and error to figure out what rmp works best for your particular application.
Old Mar 12, 2009 | 09:40 AM
silver-mod-o's Avatar
Hunt&Fisherator
Bringing mine up to 1600ish then rolling into it on the last yellow seems to be the best for me so far, but I still need LOTS of suspension work... Hopefully on the next setup I can get it to where I can leave on 6-8psi, and let 'er rip
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
moregrip
Jul 26, 2016 11:21 AM
bluestang50
Sep 21, 2015 08:36 AM
elir_mn
Sep 19, 2015 11:43 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
