Important question
What will it take to get my rcsb 4.8 4l60e into the mid 13's to low 13 or possibly a high 12? I really want to get it that way soon so as much help as possible will be greatly appreciated.
STS, 48lb injectors, custom tune, cam.
Or you could do a forged lowerend, LS1 heads (p&p'd), matching cam and other engine **** for about $2100.00. Then get the sts, injectors and a tune and run 11's
to get mid 13s you have to have either a turbo, or n20, or maybe a centrifugal superhcharger
but no way on motor, especially in the 12s
the cheapest and easiest way IMO is a 100-150shot
4.10s, tune, tires, progressive 150...40%-100% 2 sec build time coming on at about 1800 rpm (right before stock converter) then it will flash a lot higher around 2500 due to all the extra torque from the spray and if the tires hook with the 4.10s in the rear you will be looking at a low 13 or high 12 like you want.
gaps
Oct 15, 2015 02:53 PM
carid
Sep 10, 2015 09:07 AM
