TIME SLIP DATABASE
I need some feedback
Old Aug 25, 2015 | 02:14 PM
Forcefed81's Avatar
Default I need some feedback
I took my truck the drag strip for the first time the other day, 1/8 mile. I made two passes. you can see the time slips below. Everything I have done to the truck is in my sig. Are these decent times? I have to be honest, I expected a little more. I was really hoping to be in the 9's. I know I could use a converter, but I was just curious what some of the more experienced thought. Any input would be appreciated.
Attached Thumbnails I need some feedback-time-slip-1.jpg   I need some feedback-time-slip-2.jpg
Old Aug 25, 2015 | 04:55 PM
black00chev's Avatar
Slowest turbo build ever!
Definitely need a converter, just like I do. 2wd I'm assuming? Also what tires did you run on?
The 60ft times are telling me you must be spinning or leaving very soft out of the hole.
Old Aug 25, 2015 | 08:07 PM
LARRY01Z28's Avatar
sticky tire and a verter
Old Aug 25, 2015 | 08:39 PM
Gadgetized's Avatar
Do you have a tune? That is the best bang for your buck. As mentioned a converter would certainly help. What gears do you have in the rear?
Old Aug 25, 2015 | 09:01 PM
Forcefed81's Avatar
No spinning. Yeah I'm 2wd. My tires are 245/70-17's. I believe they are about 30.5" tall. I didn't try to stall it up on the start line either. I just floored it when the green light lit.
Yeah I have a tune. It's a mail order nelson tune. I'm sure I could benefit more from a dyno tune or a street tune, but that's what I've got for now. I'm running 4.30 gears.
Old Aug 25, 2015 | 09:18 PM
ZO6Ted's Avatar
Converter or a shot of Nitrous. Its your 60' that totally sucks. Mph is good for mid 9's. Then go from there and you should whittle it down to 8's. Do one of the above and you'll be much much happier I promise!
Old Aug 25, 2015 | 09:35 PM
gamble686's Avatar
Needs a converter those gears are perfect for your tire size, but that is a good size cam. Really need a stall in a bad way around 3200 at least. I bet you could knock a full second off your 1/8th.
Old Aug 26, 2015 | 08:10 AM
Forcefed81's Avatar
Thanks for the info guys I really appreciate it. Looks like a converter will be my future.
Old Aug 26, 2015 | 05:32 PM
Don't take as long as I have to get one!
Just to give you an idea. After my cam swap and good tune, I only picked up .1 in the 1/8, but gained 5mph. My 60ft times were also the same as before the swap.
JordanH
Feb 28, 2017 07:22 PM
elir_mn
Sep 19, 2015 11:43 AM
vmaxpro
Aug 30, 2015 01:40 PM
Zack R
Aug 3, 2015 06:02 PM
