TIME SLIP DATABASE
i hit a wall performance wise and im getting annoyed
Old Mar 22, 2010 | 02:21 PM
jkru617's Avatar
At least it looks better with the fast intake and bogarts lol. I wanna see some 1/4 mile times with the new setup. Wasnt your 7.72 in really good weather? What were you consistently running in the 1/8 before?
Old Mar 22, 2010 | 02:22 PM
TXsilverado's Avatar
Originally Posted by ap2002
hey stew, how about your 60', did it go down? either way you see it you are racing a truck and it needs all the lowend it can get, work on the lowend since that is where it counts on a big truck... throw the 4.56's in there and get it over with....
my 60' was 1.68 which matches my last personal best with a 125 shot out of the hole.
Old Mar 22, 2010 | 02:30 PM
ap2002's Avatar
last personal best, but you have 60' a 1.68 before on the old setup right?
Old Mar 22, 2010 | 02:44 PM
SincalT/A's Avatar
What's your compression?
Looks like you need to increase the mechanical advantage on that pig i.e increase compression or gearing.I would shoot for compression first.I know its not the cheapest idea but i think you realize no idea other then dialing in your tune is gonna benifit power at this point.
Old Mar 22, 2010 | 04:17 PM
Patrick G's Avatar
LS1 Tech Administrator
You really need a data log while you're running at WOT. If your ETC tables were not modified in your tune, your throttle could be closing at WOT because you've exceeded the Max MAF airflow or max ETC airflow. This happens a lot with Corvettes.
You need to log the truck and see if your throttle is staying open 100% the entire run. You need to log to see if your timing is good 100% the entire run and of course you need to log the air/fuel to see if it's good 100% of the way.
Old Mar 22, 2010 | 04:26 PM
11.0:1 compression. it's a cable throttle body so i know the blade is open all the time. the other stuff is questions for wheatley. im sure he covered all of that stuff though.
Old Mar 22, 2010 | 04:46 PM
GMCtrk's Avatar
I'd bet its due to the torque you lost below 5500.
Old Mar 22, 2010 | 04:58 PM
nope. best 60' on the fuddle was 1.69. i did 1.68 with a 125 out of the hole, but it was summer so i was only cutting 1.80 60' times that day N/A
Old Mar 22, 2010 | 04:59 PM
my truck spends about 95% of it's run above 5500 rpm. im cutting better 60' times so i dont see how the below 5500rpm rule applies here.
Old Mar 22, 2010 | 05:23 PM
Bumpers's Avatar
throw the 4.56s in and see what it does
