TIME SLIP DATABASE
how much do heads drop quartermile times?
Old Apr 13, 2009 | 09:57 PM
jophuss36's Avatar
Default how much do heads drop quartermile times?
So I picked up my new trickflow 225heads .04 head gasket going to be running 11.65:1 compresion with yellaterra shaft mount rockers! How much do you think this will drop my et with a good tune?
Old Apr 14, 2009 | 06:02 AM
sickREDsierra's Avatar
those are fairly LARGE intake runners for the mods, with a lifted truck and wide LSA....
i would hope for .5 at least, lots of variables here, like tire size at the track, traction, shift points, and how good the tune is.
Old Apr 14, 2009 | 08:33 AM
BlackGMC's Avatar
Resident Retard
Originally Posted by jophuss36
11.65:1 compresion
WOW that is alot... Depending on what DCR your running, your either going to have to run race gas or very very low timing...
Old Apr 14, 2009 | 10:29 AM
jophuss36's Avatar
yaw those were 2 things I was worried about considering I usually do uphill sand drags, trickflow talked me into the 225. I hope I don't loose my torque down low! My buddy who does my tuning said he runs 12:1 compression on his trans am on pump gas so hopefully I get lucky!!!!
Old Apr 14, 2009 | 11:15 AM
BlackGMC's Avatar
Resident Retard
what are the Combustion camber size?
Old Apr 14, 2009 | 11:21 AM
jophuss36's Avatar
I think there around 62cc or so I just told them I was using a .040 gasket and wanted somewhere around 11.7:1 they figured out the rest
Old Apr 14, 2009 | 06:48 PM
JoeGibbSilverado's Avatar
i dad had a 79 camaro, 350 car, th350, with 2:76 gears, the car was mint, and all original, and stock. It ran 15.98 but averaged around 16.1-16.2, the car was rated at 180 horses i think. Anyways, he added the edelbrock top end kit, heads, cam and intake, threw in some 3:73's, and went 13.1's consistently, i know different cars, different engines, but its the only thing i could think of, new to the trucks, but still same principle
Old Apr 14, 2009 | 06:50 PM
GMCtrk's Avatar
My heads are 225 cc intake runner and I lost nothing down low, only gained. Compression went up from 10.1:1 to 10.6-7:1
Old Apr 14, 2009 | 07:33 PM
jophuss36's Avatar
What kind of heads are u running and how much did they drop your et?
Old Apr 14, 2009 | 07:47 PM
GMCtrk's Avatar
prc stage 1 317s.
i dont know how much they dropped et's since it was my first time to the track. Went 14.06 @ 96.6 with those heads, headers, 4.10s/trutrac and a wheatley tune on a stock lq9, stock trans and converter. it's a 2wd ext. cab short bed. I'm pretty sure it would have dropped 1-2 tenths on slicks since i could only launch at half throttle
