TIME SLIP DATABASE
how to make bogarts fit?
Old Feb 12, 2010 | 12:00 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
bluecajuns wheels dont have as much backspace as the bogarts.
ahh see senior
Old Feb 12, 2010 | 12:04 PM
TXsilverado's Avatar
Originally Posted by built408
You can also use suburban/yukon rear brakes. They use thicker rotors and dual piston calipers, the banjo bolt is also in a different location so you can run deep backspacing wheels.
is the rear calipers of the silverado a dual piston? i dont remember...its been so long since ive had them off.
will the suburban caliper bolt right up to the silverado?
Old Feb 12, 2010 | 12:21 PM
nope there single piston on the trucks you need the rotor for the caliper to work off a burban
Old Feb 12, 2010 | 12:47 PM
ill stick with the s10 plan then
Old Feb 13, 2010 | 11:43 AM
bluecajun5.3's Avatar
11 Second Truck Club
they do now along with the s10 calipers.
just did my 4/6 during the week. blue is sitting good right now
Old Feb 13, 2010 | 11:52 AM
get some pictures up fool!
Old Feb 13, 2010 | 11:54 AM
and if anyone has pictures of how much they had to grind the s10 calipers that will help too.
will my OEM silverado brake pads fit into the s10 calpiers?
Old Feb 13, 2010 | 01:54 PM
CurtD's Avatar
10 Second Truck Club
I have heard that they will fit the s-10 calipers.
Old Feb 14, 2010 | 12:00 PM
i'll get some once i get it cleaned up. working offshore right now.
Old Feb 14, 2010 | 08:41 PM
i started on 1 and spent about 20 minutes grinding and said f this lol. i ran them by a buddies and he is going to mill them down 1/16 across the top. that should do the trick.
