TIME SLIP DATABASE
Getting it dialed in - 370 with KB 2.8L
Old Oct 20, 2008 | 11:39 PM
BigKID's Avatar
Default Getting it dialed in - 370 with KB 2.8L
Went to the local 1/8 mile Sunday to get some shake down passes with the 3.5" pulley making ~10# and the new 2bar SD tune. I was trying to richen it up all day to no avail due to fuel pressure drops above 5300rpm. Time to work on the fuel system then go back and try again. Anywho... here are my two best passes of the day. http://bigkid.ls2.com/vids/BREAKAWAY_101908.wmv (7Mb so you may want to right click, save as)
Old Oct 20, 2008 | 11:47 PM
95 bright teal's Avatar
Nice your bookin it!
What would that be in the quarter?
Old Oct 21, 2008 | 12:02 AM
BigKID's Avatar
I am guessing mid 11's @ 118ish. I am hoping to have it in the low 11's when I go to Hattiesburg (1/4 mile) at the end of Nov.
Old Oct 21, 2008 | 01:43 AM
quicksilverado's Avatar
Great job Kenny. What were your short times? 1/4 times on those passes were low 11.6s to high 11.5s
Old Oct 21, 2008 | 11:08 AM
BigKID's Avatar
On the nittos 60's were in the high 1.8x range. On the Hoosiers, 1.69-1.70 leaving off idle. I tried stalling it up once and spun to a 1.80 with 18# in the tires. That was my last pass of the day. Next time I go back I will lower the pressure and see if I can stick it for a low 1.6x.
Old Oct 21, 2008 | 11:25 AM
litreddevil's Avatar
Banned
looking good kenny you got that thing moven out.how does the 3600 stall drive around,what is the run down of you r setup.i am kinda of woundering about the stall cause i am going with a 3800 to 4000 in my truck woundering how good it drives around town.
Old Oct 21, 2008 | 12:17 PM
BigKID's Avatar
It feels pretty good around town. Moderate accleration is usually in the 2000-2300 rpm range. Mine feels a little looser around town than it really is due to the 4L80. I had basicly the same converter in my built 65 and it felt a bit tighter around town but looser on a full flash. This one feels looser around town and dosnt hit as hard on a flash. That could be a result of the 2.48 first gear I have now too.
Basicly my full setup is:
forged and studded 370
ported 241 heads
cam motion 223/229 .57x 114+4 cam
KB 2.8L w/3.5" pulley
Pacesetter headers
full 3" into single 3.5" custom mandrel exhaust
Fuddle HPTruck 9.5" 3600 conversion converter
Stock 4L80 w/Transgo HD-2
Stock 3.73 gears w/Eaton posi
Hoosier 28x10x16 on stock wheels (track)
Nitto 305/45/18 on 18x9.5 Eagle 219 (street)
Old Oct 21, 2008 | 01:47 PM
99Silverado5.3's Avatar
Not bad at all with fuel problems!!
What is your current fuel setup?
Old Oct 21, 2008 | 05:54 PM
sickREDsierra's Avatar
runs good buttwiper.
i tried to get up with you at Cruisin the Coast.. never could get you to answer. ah well.
those were some great runs man.. i will hit the track with the new converter and slicks sometime soon, i hope i run close to that time on the sauce.
Old Oct 21, 2008 | 08:22 PM
02Reaper's Avatar
Great times for your first time out Kenny. You need to quit letting the other side get the jump on ya. LOL.
