TIME SLIP DATABASE
Fuel level during racing
Old Oct 18, 2011 | 11:21 AM
foose04's Avatar
Default Fuel level during racing
Was wondering what fuel level you guys race at with stock tank setups. I still use the stock basket with two pumps and my return line flows into the basket.
I usually try and run a 1/2 a tank, but have run as low as I'd say 3/8's tank. I worry about g forces and the effect on getting fuel to the pickups.
How low do you guys go and what 1/4 time do you run.
Old Oct 18, 2011 | 11:28 AM
pittman's Avatar
I always run 1/4 tank if I get to plan it out. Still running the stock 11 yr old pump right now with 44lb injectors. Et is from 11.1 to 11-5 most of the time.
Old Oct 18, 2011 | 11:29 AM
Atomic's Avatar
I have a gauge for that
I plan to have it at least 75% full to ensure the pumps dont starve...
Old Oct 18, 2011 | 11:50 AM
custm2500's Avatar
Ph.D. in HUBRIS
Since you have such a large demand I wouldn't go any lower then you have.
Stock 40 gallon tank, stock pump set up, only running low 13 on nitrous I would run very very low fuel. 1/8th or less. I had much less demand but just figured I would offer my experiance.
Old Oct 18, 2011 | 12:24 PM
nonnieselman's Avatar
Ever thought bout running a stand alone fuel for racing?
Small 2 gallon tank under the hood.
Thought just popped in my head haha.
I was staving my pump if i got below 1/4 but had the bottom of the bucket cut out to fit the bosch 044 pump and was only runnin a 12.5@111.
I always kept it at 1/2 tank.
Old Oct 18, 2011 | 01:18 PM
lownslo's Avatar
running a single walbro in stock bucket, 11.90's at 114
never run below 1/4 tank, it will drop fuel pressure on my truck....... turbo truck with 550/594 hp/tq
Old Oct 18, 2011 | 03:24 PM
foose04's Avatar
That's what I was looking for, thanks Guys. I've had a few ideas, one being a small tank up front fed from the rear tank, then to pumps off it feeding the rails and return line still runs back to main tank. Then I could run 1/8th tank or so. Every gallon carried is what about 8 pounds extra.
Old Oct 18, 2011 | 03:32 PM
BigKID's Avatar
Running 2-255 Walbros in a cut up 99-02 bucket and 60lb injectors, mine will start cutting out between 3/16-1/8 of a tank on the street so I do not like getting below 1/4 at the track. I usually try to go to the track with between 3/8-1/2.
Old Oct 18, 2011 | 03:44 PM
TIM Z's Avatar
11 sec. Truck Mod
I try to be between half and 1/4 tank. Below qtr im afraid i will starve my pump.
Stock bucket cut to accept a single walbro 255.
Old Oct 18, 2011 | 03:51 PM
joeyc125's Avatar
11 Second Truck Club
I have a walbro 255 in the stock "modified" bucket, and used a bulkhead fitting in the lower rear of the tank to feed my second external 255. I run about 1/4 tank min. but have been caught playing around on the street with less and never ever had an issue.
