TIME SLIP DATABASE
First track visit ran a best 13.46
Old Apr 25, 2013 | 06:18 AM
gnd111's Avatar
The LSXrt is for big cubes and is probably not helping much on that combo. Also..what gear?
Old Apr 25, 2013 | 07:03 AM
ltr450ryder's Avatar
Get a 245mm 3600 stall and 4.10s if u don't have them and it be mid 12s all day
Old Jun 7, 2013 | 07:44 AM
hsiriyob's Avatar
Got my slicks from corey yesterday so im running to the track this weekend.
Old Jun 8, 2013 | 04:35 PM
hog's Avatar
hog
Originally Posted by hsiriyob
I tried stalling higher but my street tires spun. Im looking at getting some et streets so I can stall all the way.
If your tires will hold, a WOT stomp will provide the best results as it shocks the slicks more. In my experience anyways.
Dont be too concerned about actually loading your TC to it's stall speed before launching, as soon as your throttle is at WOT, you'll be at your TC's stall speed anyways. Sometimes you can flash a bit higher with a WOT stomp than if you 2 foot in an attempt to launch at higher rpm.
If you were turboed, obviously this advice wouldnt apply because you are trying to spool a turbo to launch under boost.
Great time. I think its hilarious that we have the same 60gt times, but you are 1.5 seconds quicker in the 1/4.
peace
Hog
Old Jun 8, 2013 | 04:41 PM
hog's Avatar
hog
Originally Posted by bmd_CL
Have you gotten your new injectors in yet? What gear do you have?
My bolt on 5.3 silverado with a 3200 stall and stock 3.42s on street tires will go 14.0 all day. Not hating on you at all, but i feel like a heads/cam 346 should go faster than a .5 second faster than my bolt on 323.
ET aside, I'm curiuous how does your mph stack up to his 101 mph? Once he hooks, he'll be doing much better.
peace
Hog
Old Jun 8, 2013 | 09:58 PM
hsiriyob's Avatar
peace
Hog
Thanks hog. Great advice. I did notice it launched harder on a stomp, but i didnt know why. I was only able to foot brake to about 2500 does this mean i have a 2500 stall? Its supposedly a 3k-3200 stall, but either way it needs alot more stall!
I put a walbro 255 in today, so i should have consistant fuel. Im headed to sealy in the morning for a "free" event, put on by a non sponser. Hopefully run a twelve! Im so ready!
Old Jun 8, 2013 | 10:06 PM
hsiriyob's Avatar
I actually picked up 30hp throughout the entire graph with the lsxrt and 44lb injectors. I really got the intake to plumb it for n2o. gear is a 4.10 bolted to a trutrac.
Old Jun 8, 2013 | 10:20 PM
hsiriyob's Avatar
I feel like i should be faster too! I sent you a pm.
Old Jun 9, 2013 | 11:51 AM
custm2500's Avatar
Ph.D. in HUBRIS
No brake stall speed is not your stall speed. IF you can brake stall it to 2500 then you should be able to flash to 2800-3100 easily. So you converter is about what advertised.
The slicks should get you 12s with a little bit of luck. Then you are no more then 150 shot from 11s. If you are forged and set the ring gaps correctly you should be able to spray 300+ of nitrous so just depends how much you spray for how fast you go.
Old Jun 9, 2013 | 05:03 PM
hsiriyob's Avatar
Rained out at sealy ill have to wait till next weekend
