TIME SLIP DATABASE
First time to the track with Turbo setup!
Old Apr 25, 2017 | 01:14 PM
zblee's Avatar
Default First time to the track with Turbo setup!
Silver bullet got updated fuel system on Thursday, tuned on Friday, new wheel setup installed on saturday and track event on sunday. Phew, barely made it!
Did not know what to expect . First pass i forgot to push the 'high boost ' button so it ran on gate spring pressure (made about 8psi) and ran a 12.8x @ 108mph with like a 2.1 60ft or so
Was able to shave over a second off this time later in the afternoon!
best run was 11.69 @ 117 with 1.88 60'. it was 107 degrees out! so it was not ideal!
won a trophy and some cash for having the 'closest to 12.00' run with a run i hit 11.999
cant wait to practice getting my 60' down and running in cooler weather!
my first run with a shitty 60' on high boost setting i hit a 12.04 or something and was ecstatic that i was going to be able to hit 11's. I was actually thinking that i was going to be running mid 12's but almost hitting mid 11's was the actual outcome! was pretty stoked to cut my 60's down a bit .
_zblee
Old Apr 25, 2017 | 03:42 PM
fctry286's Avatar
awesome man. thats a nice time.
Old Apr 25, 2017 | 03:53 PM
Vortec350ss's Avatar
Awesome. What is the set up exactly?
Old Apr 26, 2017 | 03:39 PM
zblee's Avatar
SBE gen3 5.3
AI 226cc 243's milled to 60cc
AI 225/229 114
e54 with dual walbro 450's
stock intake manifold
80lb Fuel injector connection injectors
trick turbo t4 hotside
dual pw46 wastegates (7.5psi spring) one in xover and one on manifold
BW S369sxe 69/73
trick 3" race coldside
FLT 4l80e
4.11 with trutrac
295/65/R15 MT et Street R in the rear
caltracs
SD tuned
weighed in at 4830 lbs with me for the time slip above
_zblee
Old Apr 26, 2017 | 03:54 PM
Awesome.
That cam is no joke in a 5.3.
What size turbo? What does "high boost" get you?
Old Apr 26, 2017 | 03:59 PM
zblee's Avatar
Awesome.
size of the BW s369 turbo is 69/73
sorry high boost setting is set for 12psi but i was only seeing a high of 11psi at the track
Old Apr 26, 2017 | 05:25 PM
Oh duh... i literally didnt see that line. I have that same turbo.
Old May 20, 2017 | 08:46 PM
zblee's Avatar
so i could not build any boost with the foot brake so i decided i need some launch control. i wired up a transbrake and a 2step . went to the track on friday and was able to get a new PB. the launch control and cooler weather were in my favor!
was able to run a 11.28 @ 118.94 with a 1.637 60 foot! was told that i need a roll cage to run faster than 11.5
_zblee
Old May 21, 2017 | 12:16 PM
terravast4's Avatar
good numbers
Old Jun 12, 2017 | 09:01 PM
banditrun10's Avatar
how did you wire in the transbrake on the P59?
