TIME SLIP DATABASE
Finally got to the track...
Old Jul 27, 2014 | 09:33 AM
DrX's Avatar
DrX
Default Finally got to the track...
...to break some parts.
Learning to launch
Old Jul 27, 2014 | 09:54 AM
BigKID's Avatar
Ouch... at least it's an easy fix. Nice times too. Was the slip in the video your best to date?
Old Jul 27, 2014 | 10:13 AM
DrX's Avatar
DrX
Yeah that was the best. 9* of timing at 18 psi. 6000lb+lb truck. Pretty sad reaction time, but I was knocking .1 off it each run. The last run would have been better if I didn't lose the DS/u-joint.
Old Jul 27, 2014 | 11:20 AM
07bluelbz's Avatar
Bad *** truck. Do you have a build thread on here?
Old Jul 27, 2014 | 12:00 PM
thewrx's Avatar
lol, twins like that are something you see on a boat setup.
Nice runs for pig for sure, 6000lb truck + 10.9 = **** ton of hp
Old Jul 27, 2014 | 01:39 PM
AkSSS's Avatar
Did you have a driveshaft hoop? Just curious how much stuff it tore up under there?
Awesome times! That thing definitely moves out!
Old Jul 27, 2014 | 01:43 PM
DrX's Avatar
DrX
Mostly broken parts threads!
Old Jul 27, 2014 | 01:47 PM
DrX's Avatar
DrX
A front loop. Banged up the fuel tank support and the evap bracket which I had already modified for clearance. Not sure about the trans, the yoke only slides out 1" then stops...just about to cut that off.
Old Jul 27, 2014 | 03:10 PM
pittman's Avatar
That thing is a beast
Old Jul 30, 2014 | 07:18 PM
silver-mod-o's Avatar
Hunt&Fisherator
Super strong as one would expect....
Needs more gear or much shorter tires though. Shifting into 3rd right before the traps isnt helping the cause. Your 60' would improve as well. Might even be able to brag about more broken parts
