TIME SLIP DATABASE
Finally got 11's
Old Apr 29, 2009 | 09:42 PM
2ktransam's Avatar
Default Finally got 11's
I made it to the track tonight with the new turbo and finally ran 11's. I went on Saturday and it was 90 degrees out so the best I could pull was a 12.4 on a **** tune. I went tonight and with cool air, a better tune and a fixed boost leak I pulled off an 11.81@112. I made three passes wich went like this.
11.90@111 Dead rich, 18 degrees of timing and 11.5psi
11.86@111 Good AFR, 18 degrees of timing and 11.5psi
11.81@112 Good AFR, 20 degrees of timing and 11.5psi
I will post up the slips and some videos in the next couple of days. I can't believe the 60e is still holding but I had my fingers crossed.
Old Apr 29, 2009 | 10:13 PM
QLF's Avatar
QLF
Very nice times man, and I wish I had a L3 trans to be amazed at that it's still holding together, I'm knocking on wood for my stock 60E lol!
Can't wait for the vids.
Old Apr 29, 2009 | 11:20 PM
getonit's Avatar
Man these 60e's will hold alot if built right. look at casper08 running 10's with a 4l60e. Congrats on the times. Bad *** for sure!
Old Apr 29, 2009 | 11:34 PM
53RUSSELL's Avatar
Very nice times. I wish i was that fast.
What is a Synergy 2 step?
Old Apr 29, 2009 | 11:38 PM
gmc6.0's Avatar
yeah im curious too what is a synergy two step
Old Apr 29, 2009 | 11:42 PM
QLF's Avatar
QLF
Only the hottest new dance move!
Nahh, I believe it's a trans brake of sorts from what I gather on a quick trip to google.
Old Apr 30, 2009 | 12:09 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Synergy Motorsports sells a 2-step. They aren't sponsors here so i cant tell you they are located in Fremont Ca.
congrats on breaking into the 11's!
Old Apr 30, 2009 | 12:17 AM
gmc6.0's Avatar
lol...what happend to them anyways i was talkn to them about doin some work but lost contact..so what is a 2 step
Old Apr 30, 2009 | 01:26 AM
Parke10's Avatar
i thought synergy was a sponsor?
Old Apr 30, 2009 | 01:58 AM
fast84's Avatar
I'm assuming he has a transbrake since he's buying a 2 step. A 2 step module gives you 2 rev limiters 1 for staging and 2 for top end rev limiter. So once he pre-stages he can start spooling the turbo,then bump into the stage beams,grab the tranny brake button and go to the floor and the 2 step will go to the low rev limiter setting.When the light drops,then he releases the tranny brake button and is already on the floor and the 2 step module switches to the high rev side of the box. Had same setup on my 84 mustang. Hope that wasn't too confusing. LOL.
