TIME SLIP DATABASE
Finally getting to go to the track.
Old Nov 20, 2011 | 05:16 PM
  #31
custm2500's Avatar
Ph.D. in HUBRIS
If you start at 13.9 stock gears and slicks take you to maybe 13.5 then you are going to drop 350+ hp of nitrous and make it hook. Not possible plus chances are the motor will be in a million peices if you spray 350 through it, especialy on a stock fuel system.
Mustangs don't start at 13.9 from what I have seen so that is a rare if ever true scenario. Go from 14.2 or slower and obviously it becomes more impossible.
Old Nov 20, 2011 | 10:44 PM
  #32
Mangled03gmc's Avatar
Baltimore Whore
Oh yah I forgot trucks don't hook on slicks so a stang def will not It doesn't take 600 hp to get 12's in a freaking 2800 lb car.. Bottom line. A driver, cam, heads, stock bottom end 302 car will go damn close if not high 12's on regular tires..
Old Nov 20, 2011 | 10:48 PM
  #33
Phantom's Avatar
11 Second Club
I'm just resubscribing to this thread so I can skull **** when I get to my computer in the morning
******* retard
Old Nov 20, 2011 | 11:45 PM
  #34
1slowz71's Avatar
I think more then anything it has to do with the set up , cam specs , heads ,intake manifold ,ect....
I have 2 friends both with 5.0's , one of them did a cam spec'd by a( local 5.0 guru called mustang manny), AFR's, and went with a carb set up,5 speed and v6 mustand springs ,and some stiki tires, he went to the local 1/8 and ran 7.4's b4 those mods he was running about 9.5's
my 2nd buddy did about the same set up but with an off the shelf cam , bought at summit, he did after market heads as well and an after market intake manifold , well he was running about 9.7s when he began to mod and ended up at 9.4s regularly....
So IMO , is it possible to run 12's on a stock block 5.0 , I think so but you MUST know what your doing , the thing is that a big % of the dudes that drive them know very little to nothing about proper modding (not saying I do ), so there for most of the stangs you see on the street or track are perty slow.
Old Nov 21, 2011 | 12:39 AM
  #35
bmd_CL's Avatar
and i also think its funny that you say you can drive...you said your buddy couldnt drive for **** and then you get in and run half a second slower? maybe that should tell you something bud.
Old Nov 21, 2011 | 05:17 AM
  #36
custm2500's Avatar
Ph.D. in HUBRIS
I drove the car for 50 feet from the staging lanes. Never reving past 1500 rpm till I had to launch off the line. I also only go two tries down the strip so sorry I wasn't able to accomplish anything.
Old Nov 21, 2011 | 06:12 AM
  #37
zero2sixT's Avatar
Originally Posted by custm2500
I can drive and he admits he isn't the best at smacking gears. I drove the car from the end of the staging lanes to the water box and down the track. I never shifted it before. Also with traction being such an issue you had to hit gears lightly anyhow.
A 12 sec. mustang is hard to come by without a ton of work done.
From what I saw you couldn't drive half as good as he could. You were almost a full second slower.
Btw, e303 cam, ford explorer 302 top end (GT-40), and full exhaust will put a LX mustang in the 12s. Your buddy needs help. Back in highschool every 306 LX mustang I knew of was an 11 sec car. That was the 90s. Back when 13s were fast. Maybe its a Texas thing, IDK...
sounds gay
Old Nov 21, 2011 | 07:14 AM
  #38
custm2500's Avatar
Ph.D. in HUBRIS
zero2sixt read the post above yours. It will help explain the issues.
I am going to agree to disagree. I am not changing anyone's mind and no one is showing evidence to change my mind. Therfore we aren't getting anywhere.
If you have the secret of making a 10 second car for $1000 I would love to hear that phantom. Better yet you should wright a book and publish it. I would buy one just to see the way make anything go from 13-14 seconds and run 10s for $1000.
Old Nov 21, 2011 | 09:28 AM
  #39
zero2sixT's Avatar
Well man, I read that post and the one on the first page. You know, the one where you said you could drive. Maybe you needed to some more passes to get a feel for the car, idk.
I don't really care enough to prove you wrong. If you want to stand by what you're saying, cool
Old Nov 21, 2011 | 09:37 AM
  #40
smokeshow's Avatar
Mod with training wheels
17 second fast...
Johnny Ricer - YouTube
